My name is Heather and I am a senior undergraduate engineering student at the University of Pittsburgh. I am working fulltime this summer for a research lab on a remote sensing project and we intend to use the RAK7289 gateway to connect our LoRa-based physical communications layer to the AWS IOT Core. I am the lead for the communications portion of this project.
The end node I am primarily working with is the HELTEC WiFi LoRa 32 V3 module, programmed through the Arduino IDE. I also have the SX1262/SX1268 LoRa HAT for Raspberry Pi and have programmed the Raspberry Pi Pico using a modified version of the library supplied by the Arm Developer Ecosystem. This has not led to better results and so I will focus on the WiFi LoRa 32 V3 module.
I have logs from:
a serial monitor for the end node module showing all communication parameters of the node prior to attempting to connect and additional debug communication information about Tx and Rx frequency, timing, and data rate as shown below:
08:10:50.053 → LoRaWAN US915 Class A start!
08:10:50.053 →
08:10:50.053 → +OTAA=1
08:10:50.053 → +Class=A
08:10:50.053 → +ADR=1
08:10:50.053 → +IsTxConfirmed=1
08:10:50.053 → +AppPort=443
08:10:50.053 → +DutyCycle=10000
08:10:50.053 → +ConfirmedNbTrials=8
08:10:50.053 → +ChMask=00000000000000000000FF00
08:10:50.053 → +DevEui=5643CA480000883C(For OTAA Mode)
08:10:50.053 → +AppEui=AC1F09FFFE104A0D(For OTAA Mode)
08:10:50.089 → +AppKey=–REDACTED–(For OTAA Mode)
08:10:50.089 → +NwkSKey=–REDACTED–(For ABP Mode)
08:10:50.089 → +AppSKey=–REDACTED–(For ABP Mode)
08:10:50.089 → +DevAddr=007E6AE1(For ABP Mode)
08:10:50.089 →
08:10:50.089 →
08:10:50.089 → joining…
08:10:50.089 → TX on freq 904900000 Hz DR 3 power 20
08:10:50.089 → LoRa MAC status is good.
08:10:50.175 → Event : Tx Done
08:10:55.121 → RX on freq 926300000 Hz at DR 13
08:10:55.386 → Event : Rx Timeout
08:10:56.165 → RX on freq 923300000 Hz at DR 8
08:10:56.261 → Event : Rx Timeout
08:10:57.085 → TX on freq 904300000 Hz DR 3 power 20
08:10:57.178 → Event : Tx Done
08:11:02.127 → RX on freq 924500000 Hz at DR 13
08:11:02.395 → Event : Rx Timeout
08:11:03.173 → RX on freq 923300000 Hz at DR 8
08:11:03.245 → Event : Rx Timeout
08:11:04.121 → TX on freq 904500000 Hz DR 3 power 20
08:11:04.199 → Event : Tx Done -
RAK7289 gateway logs, in Debug mode, centered around the attempted communication as shown below:
Wed Jun 26 12:08:02 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:02] “GET /dashboard/lora/statistics HTTP/1.0” 200 -
Wed Jun 26 12:08:06 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:06] “GET /net/lan HTTP/1.0” 200 -
Wed Jun 26 12:08:06 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:06] “GET /net/wan HTTP/1.0” 200 -
Wed Jun 26 12:08:07 2024 user.debug basicstation[23794]: [LOG:DEBU] logger read datas: dutycycle
Wed Jun 26 12:08:07 2024 user.debug basicstation[23794]: [LOG:VERB] dutycycle size: 65910
Wed Jun 26 12:08:07 2024 user.debug basicstation[23794]: [LOG:DEBU] logger write datas size: 65910
Wed Jun 26 12:08:07 2024 user.debug basicstation[23794]: [LOG:DEBU] close logger connection [8].
Wed Jun 26 12:08:08 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:08] “GET /dashboard/overview HTTP/1.0” 200 -
Wed Jun 26 12:08:15 2024 user.info basicstation[23794]: [SYN:INFO] PPS/SX130X drift stats: min: -0.5ppm q50: -0.7ppm q80: -0.8ppm max: -1.0ppm - threshold q80: -0.8ppm
Wed Jun 26 12:08:17 2024 user.info basicstation[23794]: [SYN:INFO] Time sync qualities: min=683 q90=1475 max=48110 (previous q90=920)
Wed Jun 26 12:08:17 2024 user.info basicstation[23794]: [SYN:INFO] MCU/SX130X drift stats: min: +0.8ppm q50: +7.7ppm q80: -32.2ppm max: +40.6ppm - threshold q90: -40.6ppm
Wed Jun 26 12:08:17 2024 user.info basicstation[23794]: [SYN:INFO] Mean MCU drift vs SX130X#0: 2.3ppm
Wed Jun 26 12:08:36 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:36] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:38 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:38] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:40 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:40] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:43 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:43] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:45 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:45] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:47 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:47] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:49 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:49] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:52 2024 user.info basicstation[23794]: [RAL:INFO] RX mod=LORA f=904500000 bw=9 sz=52 dr=9 E00BC649A4E65886C5B761C10203A8A107672250E77A08DC63E531E3515B55D21F1C81378319E38A69D7C5DDC4330008A9734A3D
Wed Jun 26 12:08:52 2024 user.debug basicstation[23794]: [LOG:DEBU] rrd_statistic_up-357 uplinkTqByAirtime: dr=1, timeonair=328, tm=1719403732
Wed Jun 26 12:08:52 2024 user.debug basicstation[23794]: [LOG:DEBU] rrd_statistic_up-359 uplinkTqByPkt: dr=1, tm=1719403732
Wed Jun 26 12:08:52 2024 user.debug basicstation[23794]: [LOG:DEBU] rrd_statistic_up-361 ChanBusyByAirtime: chan=3, timeonair=328, tm=1719403732
Wed Jun 26 12:08:52 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:52] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:56 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:56] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:08:58 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:08:58] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:01 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:01] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:04 2024 user.info basicstation[23794]: [SYN:INFO] MCU/SX130X drift stats: min: -1.7ppm q50: +17.2ppm q80: -40.0ppm max: +63.3ppm - threshold q90: +51.7ppm
Wed Jun 26 12:09:04 2024 user.info basicstation[23794]: [SYN:INFO] Mean MCU drift vs SX130X#0: 3.8ppm
Wed Jun 26 12:09:04 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:04] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:07 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:07] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:08 2024 user.info basicstation[23794]: [SYN:INFO] PPS/SX130X drift stats: min: -0.5ppm q50: -0.7ppm q80: -0.7ppm max: -1.0ppm - threshold q80: -0.7ppm
Wed Jun 26 12:09:10 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:10] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:12 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:12] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:14 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:14] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:16 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1648 threshold=1475
Wed Jun 26 12:09:16 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:16] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:19 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:19] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:21 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:21] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:23 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:23] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:25 2024 user.info basicstation[23794]: [SYN:INFO] Time sync qualities: min=683 q90=997 max=1648 (previous q90=1475)
Wed Jun 26 12:09:26 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:26] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:29 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:29] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:32 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:32] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:35 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:35] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:38 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1547 threshold=997
Wed Jun 26 12:09:38 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:38] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:41 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:41] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:43 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:43] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:46 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:46] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:49 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1038 threshold=997
Wed Jun 26 12:09:49 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:49] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:51 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1341 threshold=997
Wed Jun 26 12:09:51 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:51] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:54 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:54] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:55 2024 user.info basicstation[23794]: [SYN:INFO] MCU/SX130X drift stats: min: +1.5ppm q50: +23.5ppm q80: -44.9ppm max: +195.4ppm - threshold q90: -80.5ppm
Wed Jun 26 12:09:55 2024 user.info basicstation[23794]: [SYN:INFO] Mean MCU drift vs SX130X#0: 7.5ppm
Wed Jun 26 12:09:57 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:57] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:09:59 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:09:59] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:01 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:01] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:03 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:03] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:05 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1235 threshold=997
Wed Jun 26 12:10:05 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:05] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:07 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:07] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:07 2024 user.info basicstation[23794]: [SYN:INFO] PPS/SX130X drift stats: min: -0.5ppm q50: -0.7ppm q80: -1.0ppm max: -1.0ppm - threshold q80: -1.0ppm
Wed Jun 26 12:10:10 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:10] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:13 2024 user.notice data-broker: data-broker timeout, restart it
Wed Jun 26 12:10:13 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:13] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:16 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:16] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:19 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:19] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:21 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:21] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:22 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1080 threshold=997
Wed Jun 26 12:10:23 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:23] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:26 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:26] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:28 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:28] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:30 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:30] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:33 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:33] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:34 2024 user.info basicstation[23794]: [SYN:INFO] Time sync qualities: min=682 q90=1235 max=1547 (previous q90=997)
Wed Jun 26 12:10:35 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:35] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:37 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:37] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:40 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:40] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:43 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:43] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:46 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:46] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:47 2024 user.info basicstation[23794]: [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm q50: +20.6ppm q80: +51.7ppm max: +131.1ppm - threshold q90: -86.1ppm
Wed Jun 26 12:10:47 2024 user.info basicstation[23794]: [SYN:INFO] Mean MCU drift vs SX130X#0: 6.9ppm
Wed Jun 26 12:10:49 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:49] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:50 2024 daemon.warn wpa_supplicant[4030]: apcli0: Undefined secondary channel: drop OBSS scan results
Wed Jun 26 12:10:52 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:52] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:55 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:55] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:10:58 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=2086 threshold=1235
Wed Jun 26 12:10:58 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:10:58] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:01 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:01] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:02 2024 user.info basicstation[23794]: [SYN:INFO] PPS/SX130X drift stats: min: -0.5ppm q50: -0.7ppm q80: -0.8ppm max: -1.0ppm - threshold q80: -0.8ppm
Wed Jun 26 12:11:04 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:04] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:07 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:07] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:10 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:10] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:13 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:13] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:16 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:16] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:17 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1262 threshold=1235
Wed Jun 26 12:11:19 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:19] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:21 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:21] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:24 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:24] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:27 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:27] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:30 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:30] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:33 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:33] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:36 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1473 threshold=1235
Wed Jun 26 12:11:36 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:36] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:39 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:39] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:40 2024 user.info basicstation[23794]: [SYN:INFO] MCU/SX130X drift stats: min: -1.1ppm q50: -24.4ppm q80: +40.1ppm max: -57.2ppm - threshold q90: +46.6ppm
Wed Jun 26 12:11:40 2024 user.info basicstation[23794]: [SYN:INFO] Mean MCU drift vs SX130X#0: 4.1ppm
Wed Jun 26 12:11:42 2024 user.info basicstation[23794]: [SYN:INFO] Time sync qualities: min=705 q90=1262 max=2086 (previous q90=1235)
Wed Jun 26 12:11:42 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:42] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:43 2024 user.info basicstation[23794]: [SYN:INFO] Time sync: NOW ustime=0x00099017DED0 utc=0x61BC9EAEA13D6 gpsOffset=0x4FC6BA2362400 ppsOffset=339142 syncQual=921
Wed Jun 26 12:11:43 2024 user.info basicstation[23794]: [SYN:INFO] Time sync: MCU/SX130X#0 ustime=0x00099001C56B xtime=0xC30000244C6A0C pps_ustime=0x98FFBA67A pps_xtime=0xC3000024464B1B
Wed Jun 26 12:11:43 2024 user.info basicstation[23794]: [SYN:INFO] Time sync: Last PPS ustime=0x00099001C56B xtime=0xC30000244C6A0C pps_ustime=0x98FFBA67A pps_xtime=0xC3000024464B1B
Wed Jun 26 12:11:43 2024 user.info basicstation[23794]: [SYN:INFO] Time ref: Last PPS sys->UTC=12:11:42.000000 SX130X->GPS=12:12:00.000000 leaps=18s diff=0
Wed Jun 26 12:11:45 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:45] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:48 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:48] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:49 2024 user.debug basicstation[23794]: [SYN:VERB] Time sync rejected: quality=1339 threshold=1262
Wed Jun 26 12:11:50 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:50] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:53 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:53] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:56 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:56] “GET /diag/syslog HTTP/1.0” 200 -
Wed Jun 26 12:11:59 2024 user.info restify: 127.0.0.1 - - [26/Jun/2024 12:11:59] “GET /diag/syslog HTTP/1.0” 200 - -
AWS IOT Trace Messaging, showing the Join_Request reception along with the Device Eui and a timestamp
