Are the RAK7289 WisGate Edge Pro compatible with TheThingsNetwork and TheThingsIndustries ?
Provided you purchase a gateway of the correct frequency band used by TTN for your region, it would be compatible with TTN in classic UDP packet forwarder mode.
There’s also evolving support for Basicstation mode, see various existing threads here for the latest status of that.
Many thanks! I will check it
As for the Basics station mode you can use this guide as it is fully compatible with RAK7289, until the specific guides for RAK7289 are uploaded:
Best Regards
Thank you. I will do.
