Configuring Wisgate Edge Pro RAK7289C with AWS using basic station. Created a gateway in AWS and configured the Wisgate for basic station with TLS and it connects to AWS as it should, but after cycling the power it will not re-connect to AWS and the LoRa LED on the gateway is off. If I go into the webUI, select the LoRa Network Settings page all info is there. If I simply press the Save&Apply button but change nothing in the setup the changes are applied and the gateway instantly connects to AWS. If I then cycle power to the gateway it does not connect after powering up. GW firmware is latest 1.3.4_RAK b113. The WisDM feature is disabled.
