The gateway has specified a DC 12V / 1A input for the power supply.
Are strict 12V required here or is the device also approved for a variable voltage range?
The reason I ask is because I would like to operate the device with a lithium battery, which has a variable voltage range of approx. 10V - 12.6V.
Yes, we offer the battery options linked below for the RAK7289CV2:
RAK9155 Battery Plus Datasheet | RAKwireless Documentation Center
I see so based on the specs of the RAK battery I can assume that the wisgate can handle DC inputs ranging from 10 V to 14.6 V right?
The gateway should handle DC in this range 11.2-14.4V .
14.6 may cause trouble, I wouldn’t plug it in like that.
