RAK7289V2 - 16 channels not usable in Basic Station mode
I’m currently trying to connect my RAK7289V2 Gateway (WisGateOS_2.2.11_RAK) to my ChirpStack LNS using Basic Station.
Unfortunately, I’m currently struggling with the configuration of the ChirpStack Gateway Bridge to use all 16 channels.
As soon as I configure an additional backend.basic_station.concentrators section, the RAK gateway refuses to work and logs the following error:
basicstation[10163]: [RAL:ERRO] Unsupported hwspec=sx1301/2
However, the device is definitely the 16-channel variant.
Is this a configuration error on my side or could this be a firmware bug?
My current ChirpStack Gateway Bridge configuration looks like this:
  # Region.
  region="EU868"
  # Minimal frequency (Hz).
  frequency_min=863000000
  # Maximum frequency (Hz).
  frequency_max=870000000
[[backend.basic_station.concentrators]]
  # Multi-SF channels - first concentrator
  [backend.basic_station.concentrators.multi_sf]
  frequencies=[
    865900000,
    866100000,
    866300000,
    866500000,
    866700000,
    866900000,
    867100000,
    867300000,
  # Multi-SF channels - second concentrator
  frequencies=[
    867500000,
    867700000,
    867900000,
    868100000,
    868300000,
    868500000,
  # LoRa STD channel
  [backend.basic_station.concentrators.lora_std]
  frequency=868300000
  bandwidth=250000
  spreading_factor=7
  # FSK channel
  [backend.basic_station.concentrators.fsk]
  frequency=868800000
Log from the RAK:
Fri Feb 28 14:21:52 2025 user.info basicstation[10163]: [AIO:INFO] tc has no key+cert configured - running server auth only
Fri Feb 28 14:21:52 2025 user.info basicstation[10163]: [TCE:INFO] Connecting to MUXS...
Fri Feb 28 14:21:53 2025 user.info basicstation[10163]: [TCE:INFO] Connected to MUXS.
Fri Feb 28 14:21:53 2025 user.debug basicstation[10163]: [AIO:DEBU] [7|WS] > {"msgtype":"version","station":"2.0.6(linux/std)","firmware":null,"package":null,"model":"linux","protocol":2,"features":"rmtsh gps"}
Fri Feb 28 14:21:53 2025 user.debug basicstation[10163]: [AIO:DEBU] [7|WS] < {"msgtype":"router_config","NetID":null,"JoinEui":null,"region":"EU863","hwspec":"sx1301/2","freq_range":[863000000,870000000],"DRs":[[12,125,0],[11,125,0],[10,125,0],[9,125,0],[8,125,0],[7,125,0],[7,250,0],[0,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0]],"sx1301_conf":[{"radio_0":{"enable":true,"freq":866300000},"radio_1":{"enable":true,"freq":867300000},"chan_FSK":{"enable":false},"chan_Lora_std":{"enable":false,"radio":0,"i
Fri Feb 28 14:21:53 2025 user.debug basicstation[10163]: [AIO:DEBU] [7|WS] . f":0},"chan_multiSF_0":{"enable":true,"radio":0,"if":-400000},"chan_multiSF_1":{"enable":true,"radio":0,"if":-200000},"chan_multiSF_2":{"enable":true,"radio":0,"if":0},"chan_multiSF_3":{"enable":true,"radio":0,"if":200000},"chan_multiSF_4":{"enable":true,"radio":0,"if":400000},"chan_multiSF_5":{"enable":true,"radio":1,"if":-400000},"chan_multiSF_6":{"enable":true,"radio":1,"if":-200000},"chan_multiSF_7":{"enable":true,"radio":1,"if":0}},{"radio_0":{"enable":
Fri Feb 28 14:21:53 2025 user.debug basicstation[10163]: [AIO:DEBU] [7|WS] . true,"freq":867900000},"radio_1":{"enable":true,"freq":868675000},"chan_FSK":{"enable":true},"chan_Lora_std":{"enable":true,"radio":1,"if":-375000,"bandwidth":250000,"spread_factor":7},"chan_multiSF_0":{"enable":true,"radio":0,"if":-400000},"chan_multiSF_1":{"enable":true,"radio":0,"if":-200000},"chan_multiSF_2":{"enable":true,"radio":0,"if":0},"chan_multiSF_3":{"enable":true,"radio":0,"if":200000},"chan_multiSF_4":{"enable":true,"radio":0,"if":400000},"chan
Fri Feb 28 14:21:53 2025 user.debug basicstation[10163]: [AIO:DEBU] [7|WS] . _multiSF_5":{"enable":true,"radio":1,"if":-175000},"chan_multiSF_6":{"enable":false,"radio":0,"if":0},"chan_multiSF_7":{"enable":false,"radio":0,"if":0}}],"MuxTime":1740752513.306311}
Fri Feb 28 14:21:53 2025 user.err basicstation[10163]: [RAL:ERRO] Unsupported hwspec=sx1301/2
Fri Feb 28 14:21:53 2025 user.err basicstation[10163]: [any:ERRO] Closing connection to muxs - error in s2e_onMsg
Fri Feb 28 14:21:53 2025 user.warn basicstation[10163]: [AIO:WARN] [7] ws_close reason=1000
Fri Feb 28 14:21:53 2025 user.debug basicstation[10163]: [AIO:DEBU] Echoing close - reason=1000
Fri Feb 28 14:21:53 2025 user.warn basicstation[10163]: [AIO:WARN] [7|WS] Server sent close: reason=1000
Fri Feb 28 14:21:53 2025 user.warn basicstation[10163]: [AIO:WARN] [7] WS connection shutdown...
Fri Feb 28 14:21:53 2025 user.debug basicstation[10163]: [TCE:VERB] Connection to MUXS closed in state -1
Fri Feb 28 14:21:53 2025 user.info basicstation[10163]: [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
Log from the ChirpStack Gateway Bridge:
Feb 28 14:21:52 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:52.543537126Z" level=info msg="backend/basicstation: router-info request received" gateway_id=xxxxxxxxxxxxxxxx remote_addr="10.15.1.33:53748" router_uri="wss://lns.iot.xxxxxxx.de:443/gateway/xxxxxxxxxxxxxxxx"
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.284978531Z" level=info msg="backend/basicstation: gateway connected" gateway_id=xxxxxxxxxxxxxxxx remote_addr="10.15.1.33:53756"
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.285025496Z" level=debug msg="integration/mqtt: set gateway subscription" gateway_id=xxxxxxxxxxxxxxxx subscribe=true
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.285059519Z" level=debug msg="integration/mqtt: gateway subscription set" gateway_id=xxxxxxxxxxxxxxxx subscribe=true
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.306241686Z" level=debug msg="backend/basicstation: message received" gateway_id=xxxxxxxxxxxxxxxx message="{\"msgtype\":\"version\",\"station\":\"2.0.6(linux/std)\",\"firmware\":null,\"package\":null,\"model\":\"linux\",\"protocol\":2,\"features\":\"rmtsh gps\"}"
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.306297816Z" level=info msg="backend/basicstation: gateway version received" firmware= gateway_id=xxxxxxxxxxxxxxxx model=linux package= protocol=2 station="2.0.6(linux/std)"
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.306443601Z" level=debug msg="sending message to gateway" gateway_id=xxxxxxxxxxxxxxxx message="{\"msgtype\":\"router_config\",\"NetID\":null,\"JoinEui\":null,\"region\":\"EU863\",\"hwspec\":\"sx1301/2\",\"freq_range\":[863000000,870000000],\"DRs\":[[12,125,0],[11,125,0],[10,125,0],[9,125,0],[8,125,0],[7,125,0],[7,250,0],[0,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0],[-1,0,0]],\"sx1301_conf\":[{\"radio_0\":{\"enable\":true,\"freq\":866300000},\"radio_1\":{\"enable\":true,\"freq\":867300000},\"chan_FSK\":{\"enable\":false},\"chan_Lora_std\":{\"enable\":false,\"radio\":0,\"if\":0},\"chan_multiSF_0\":{\"enable\":true,\"radio\":0,\"if\":-400000},\"chan_multiSF_1\":{\"enable\":true,\"radio\":0,\"if\":-200000},\"chan_multiSF_2\":{\"enable\":true,\"radio\":0,\"if\":0},\"chan_multiSF_3\":{\"enable\":true,\"radio\":0,\"if\":200000},\"chan_multiSF_4\":{\"enable\":true,\"radio\":0,\"if\":400000},\"chan_multiSF_5\":{\"enable\":true,\"radio\":1,\"if\":-400000},\"chan_multiSF_6\":{\"enable\":true,\"radio\":1,\"if\":-200000},\"chan_multiSF_7\":{\"enable\":true,\"radio\":1,\"if\":0}},{\"radio_0\":{\"enable\":true,\"freq\":867900000},\"radio_1\":{\"enable\":true,\"freq\":868675000},\"chan_FSK\":{\"enable\":true},\"chan_Lora_std\":{\"enable\":true,\"radio\":1,\"if\":-375000,\"bandwidth\":250000,\"spread_factor\":7},\"chan_multiSF_0\":{\"enable\":true,\"radio\":0,\"if\":-400000},\"chan_multiSF_1\":{\"enable\":true,\"radio\":0,\"if\":-200000},\"chan_multiSF_2\":{\"enable\":true,\"radio\":0,\"if\":0},\"chan_multiSF_3\":{\"enable\":true,\"radio\":0,\"if\":200000},\"chan_multiSF_4\":{\"enable\":true,\"radio\":0,\"if\":400000},\"chan_multiSF_5\":{\"enable\":true,\"radio\":1,\"if\":-175000},\"chan_multiSF_6\":{\"enable\":false,\"radio\":0,\"if\":0},\"chan_multiSF_7\":{\"enable\":false,\"radio\":0,\"if\":0}}],\"MuxTime\":1740752513.306311}"
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.30651382Z" level=info msg="backend/basicstation: router-config message sent to gateway" gateway_id=xxxxxxxxxxxxxxxx
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.341119555Z" level=info msg="backend/basicstation: gateway disconnected" gateway_id=xxxxxxxxxxxxxxxx remote_addr="10.15.1.33:53756"
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.34121322Z" level=debug msg="integration/mqtt: set gateway subscription" gateway_id=xxxxxxxxxxxxxxxx subscribe=false
Feb 28 14:21:53 srv-chirpstack chirpstack-gateway-bridge[4681]: time="2025-02-28T14:21:53.341283673Z" level=debug msg="integration/mqtt: gateway subscription set" gateway_id=xxxxxxxxxxxxxxxx subscribe=false
Did you ever figure this out? I am seeing the same thing with Basicstation but not with the packet forwarder. I can do 8 on any subband but once I go to 16 I get this error with basicstation.
I should say that I’m using the RAK7249 gateway but not on Chirpstack currently. The old semtech packet forwarder worked like a charm with Class B even. I’m hoping that there is something that I’m missing in the station.conf perhaps. :face_with_raised_eyebrow:
So you are using RAK7249, is that correct?
This product is V1 and EOL, so no features will be added.
For the V2 gateway (like in the original post, RAK7289V2), we expect a fix for the 16ch BS mode soon.
Nikola Semov
