I’ve got a few questions about these two gateways and their geolocation capabilities with TDoA and RSSI through triangulation.
What level of node location accuracy can I expect with either of these gateways?
Does the orientation of the 3 gateways need to be in an equilateral (perfect triangle) orientation? Will it work the same if the 3 gateways are in an obtuse orientation? I can’t see that this would have any huge affect on the accuracy so long as two antennas aren’t too close to each other.
What sort of node location accuracy can I expect if a node falls outside of the gateway triangle but still within reach of all 3 gateways?
Is the LBT feature available with these gateways on chirpstack?
