Attempted to connect, TTGO LORA32 end node to RAK7391 gateway following example as a base, using OTAA connection. Noted that No JoinAccept message occured at end node, checked gateway logs and noted that downlink appeared to occur but apparently did not, as looking into udp-packet forwarder container log noted that no bytes were sent to the concentrator. I am really new to this so please advise on how to get downlink to work.
Rakpios version: rakpios-0.7.0
##### 2023-06-01 08:32:53 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 0
# CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 0 (0 bytes)
# PUSH_DATA datagrams sent: 1 (123 bytes)
# PUSH_DATA acknowledged: 0.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (0.00% acknowledged)
# PULL_RESP(onse) datagrams received: 0 (0 bytes)
# RF packets sent to concentrator: 0 (0 bytes)
# TX errors: 0
### SX1302 Status ###
# SX1302 counter (INST): 2158505242
# SX1302 counter (PPS): 0
# BEACON queued: 0
# BEACON sent so far: 0
# BEACON rejected: 0
### [JIT] ###
src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
### [GPS] ###
# Invalid time reference (age: 1685608373 sec)
# no valid GPS coordinates available yet
##### END #####
JSON up: {"stat":{"time":"2023-06-01 08:32:53 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0,"temp":51.3}}
SPECTRAL SCAN - 923600000 Hz: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 848 1152 0 0 0 0 0 0 0 0 0
INFO: Received pkt from mote: 4E8AB923 (fcnt=42092)
JSON up: {"rxpk":[{"jver":1,"tmst":2171880478,"chan":1,"rfch":0,"freq":923.400000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","rssis":-81,"lsnr":13.2,"foff":-9608,"rssi":-80,"size":23,"data":"ACO5ik4ubKS40Lf9XL4aLOoxL12Octk="}]}
SPECTRAL SCAN - 923800000 Hz: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 17 1089 859 35 0 0 0 0 0 0 0 0
SPECTRAL SCAN - 924000000 Hz: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 17 1211 361 411 0 0 0 0 0 0 0 0
##### 2023-06-01 08:33:23 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 1
# CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 1 (23 bytes)
# PUSH_DATA datagrams sent: 2 (374 bytes)
# TX errors: 0
# SX1302 counter (INST): 2188518068
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1685608403 sec)
##### END #####
udp packet forwarder log
Things network Live data
version: '2'
services:
udp-packet-forwarder:
image: rakwireless/udp-packet-forwarder:latest
container_name: udp-packet-forwarder
restart: unless-stopped
networks:
- bridge
devices:
- /dev/gpiochip0
- /dev/ttyACM0
- /dev/i2c-1
volumes:
- /sys:/sys
environment:
MODEL: "RAK5146"
CONCENTRATOR: "SX1303"
INTERFACE: "USB"
HAS_GPS: "1"
HAS_LTE: "0"
RESET_GPIO: 0
GPS_DEV: "/dev/i2c-1"
RADIO_DEV: "/dev/ttyACM0"
GATEWAY_EUI: "E45F01FFFEB93BC2"
BAND: "as_915_928"
SERVER_HOST: 192.168.0.119
SERVER_PORT: 1700
postgres:
image: postgres:14.3-alpine3.15
container_name: postgres
environment:
- POSTGRES_PASSWORD=root
- POSTGRES_USER=root
- POSTGRES_DB=ttn_lorawan
networks:
- bridge
volumes:
- 'postgres:/var/lib/postgresql/data'
ports:
- "5432:5432"
redis:
image: redis:7.0.0-alpine3.15
container_name: redis
command: redis-server --appendonly yes
networks:
- bridge
volumes:
- 'redis:/data'
ports:
- "6379:6379"
stack:
image: xoseperez/the-things-stack:latest
container_name: stack
depends_on:
- redis
- postgres
networks:
- bridge
volumes:
- 'stack-blob:/srv/ttn-lorawan/public/blob'
- 'stack-data:/srv/data'
environment:
TTS_DOMAIN: 192.168.0.119
CLI_AUTO_LOGIN: "true"
TTN_LW_BLOB_LOCAL_DIRECTORY: /srv/ttn-lorawan/public/blob
TTN_LW_REDIS_ADDRESS: redis:6379
TTN_LW_IS_DATABASE_URI: postgres://root:root@postgres:5432/ttn_lorawan?sslmode=disable
WAIT_HOSTS: redis:6379, postgres:5432
WAIT_HOSTS_TIMEOUT: 300
WAIT_SLEEP_INTERVAL: 30
WAIT_HOST_CONNECT_TIMEOUT: 30
ports:
- "80:1885"
- "443:8885"
- "1881:1881"
- "1882:1882"
- "1883:1883"
- "1884:1884"
- "1885:1885"
- "1887:1887"
- "8881:8881"
- "8882:8882"
- "8883:8883"
- "8884:8884"
- "8885:8885"
- "8887:8887"
- "1700:1700/udp"
influxdb:
image: influxdb:1.8
container_name: influxdb
ports:
- '8086:8086'
networks:
- bridge
volumes:
- influxdb-storage:/var/lib/influxdb
environment:
- INFLUXDB_DB=sensors
- INFLUXDB_HTTP_AUTH_ENABLED=true
- INFLUXDB_ADMIN_USER=admin
- INFLUXDB_ADMIN_PASSWORD=changeme
grafana:
image: grafana/grafana:latest
container_name: grafana
ports:
- '3000:3000'
networks:
- bridge
depends_on:
- influxdb
volumes:
- grafana-storage:/var/lib/grafana
- ./volume/grafana/provisioning/:/etc/grafana/provisioning
environment:
- GF_SECURITY_ADMIN_USER=admin
- GF_SECURITY_ADMIN_PASSWORD=changeme
node-red:
image: nodered/node-red:latest
container_name: node-red
entrypoint: /data/entrypoint.sh
environment:
- TZ=Europe/Amsterdam
ports:
- "1880:1880"
networks:
- bridge
depends_on:
- influxdb
- stack
volumes:
- ./volume/node-red/data:/data
volumes:
influxdb-storage:
grafana-storage:
node-red-data:
redis:
postgres:
stack-blob:
stack-data:
networks:
bridge:
docker-compose.yml
