I have a RAK7391 gateway with me, I logged in into its SSH successfully but I am not able to log into the gateway configuration by using “sudo gateway-config” command. It says command not found.
Can any one help me to find what might be wrong?
Hi Divya
If you are running RAKPiOS on the RAK7391 you should use rakpios-cli tool instead. gateway-config is only available with previous developer gateways.
Check RAKPiOS | RAKwireless Documentation Center
Thank you
Thank you so much for your timely reply, can you provide me with the further configuration commands and steps to make RAK7391 act as a LoRa gateway.
