Tech_Atreyo
(Atreyo Research and Development LLP)
1
I am using RAK5146 along with Chirpstack gateway OS !
LNS are internal in OS as well as external hosted by myself , both are chirpstack LNS, I have configured all the things and also fetched data (in event) in LNS.
Now, I came across one problem that after 40-50 min this node (RAK7431) goes offline or what I don’t know , but join request is not accepted by Network Server , also CLASS changes From C to A. can anyone tell is this from server side issue , gateway problem or it’s in node ?
All gateway should operate in Class C, because a Class C behavior is that listen/talk all the time. A Class A device use to be your endnodes, because they will listen only after to talk.
About the LNS, you should configure in the server side 3 LoRa keys devices and join mode OTAA.
A important easy thing it is to know if the LNS is configure in LSB(Least Signficant Bit) or MSB(Most Significant Bit) and the IDs must to be the same in the endnode side and LNS side.
DevEUI: 8 pairs of hexadecimal to identify the device
AppEUI: 8 pairs of hexadecimal to identify the application that it has a group of endnodes with a similar behavior/configuration
Appkey: 8 pairs of hexadecimal to encript the application package to be sent in a secure mode
Tech_Atreyo
3
This should be defined in LNS or Gateway ? I have Enabled Class C support in LNS (I am using Chirpstack). and End node is defined to CLASS A ,
is this correct ?
Tech_Atreyo
4
Any idea on this ? even if node sends JOIN requests almost over 24 Hrs , server is not accepting them ! I am unable to figure it out …
