Hi @shayagmon,
We’ve fixed this issue and released a new version firmware, please download from here:
https://downloads.rakwireless.com/en/LoRa/RAK811/Firmware/
Hi @shayagmon,
Thank you very much ! Confirmed that it is fixed.
Hey
Even i had the same problem with the app_key input on 9600 bps… Confirmed that the above problem is solved…
But now a new problem arises!
After sending data (at+send), the device goes into sleep mode (Go to Sleep).
When we try to send data again, theirs No response after that. A Wake Up message is shown. Further sending or entering any other AT command does not given any reply.
Kindly help with the same…
Hi @jithins,
Yes, this is an issue, and we’ll fix it ASAP, then release a new firmware in 2 days. Please wait.
Thank you!
Hi @Fomi
Thanks for acknowledging the same… It is a big bother for developers if the code that worked earlier breaks down after an upgrade… Do try to fix the issue soon… Thanks a lot…
Hi @jithins,
We’ve fixed this issue. Please download the latest firmware:
Hey @Fomi
Thanks… Confirm that the issue is resolved.
So now the device goes to sleep immediately after sending. If we send again, then the device wakes up. Only on the next send, does it send again.
Or else, before every send, we wake the module up by using the at+set_config=device:sleep:0 and then send.
Is this correct? It would be good if this is mentioned in the brochure… Thanks a lot.
Attaching screenshots for anyone who needs help with the same.
Jithin Isaac
Hi, @Fomi
I’m using RAK811 module connected to a host microcontroller via AT commands.
PA9/USART1_TX(PIN 6) and PA10/USART1_RX(PIN 10)
My host microcontroller is capable to send AT commands maximum at 9600bps.
In earlier version V2.0.3.4, I have changed baud rate to 9600bps by this command and worked.
at+uart=9600,8,0,0,0
Now upgraded to the latest version V3.0.0.11.H
I want to change baud rate to 9600bps again for the host microcontroller is able to send LORA AT commands (e.g. Join, Send, Sleep…)
I have tried that command for the latest version;
at+set_config=device:uart:1:9600
and the response is;
OK,The UART1 baud rate switch to 3.
From my microcontroller or when test PC-USB on the Wisnode Lora Module, I can not send LORA AT commands at 9600bps.
Then I tried also that;
at+set_config=device:uart_mode:1:0
Current AT uart work mode:normal mode
But It doesn’t work at 9600bps, but it still works at 115200bps.
What should I do ?
Hi, @Fomi
My custom microcontroller board has a firmware update connector for RAK811 smd module.
After firmware updated, I want uart at 9600bps configurated as well to be save non-volatile on RAK811.
My host can never send to uart at 115200bps for runtime configuration.
Yes, I want to use V3.0.0.11.H default at 9600bps and What should I do ?
Thank you
Hi,@leanofis
I’m very sorry reply so late.Yes,this is a vrey terrible bug.we will fix it quickly,and you could update fimeware to V3.0.0.12.H.
Hi, @leopold
Thank you for the response.
I wait for V3.0.0.12.H
Yes, once baud rate has been changed that must be saved non-volatile.
hey,
im using wisnode with arduino uno as a shield.
i have tried out the following codes.
and changed the baud rate to 9600 by the command
but im not getting any response
when i run the code the commands that are passed to the wisnode will be printed
like,
at+version
at+join
at+band=0
my firmware version is
Firmware Version: RUI v3.0.0.12.H
what should i do next ?
Hi @sheminanto,
I think the UART you are using may work in passthrough mode now.
You can use “+++” to change the UART to work in configuration mode firstly, and try again.
Hi @sheminanto
First "at+band=0 " is illegal instruction.
Don’t use Arduino board, directly connect to WisNode with micro USB, send instructions to see if there is a response.If no response,maybe you need modify uart mode to normal mode in @Fomi way.
If it is normal with micro USB directly,I guess you maybe use USB of Arduino board to monitor response,this method is wrong.You need use SoftwareSerial DebugSerial to monitor module .
Don’t use Arduino board, directly connect to WisNode with micro USB, send instructions to see if there is a response?
@leopold
i have connected wisnode as shield. and monitored the serilal out of arduino
can i get your contact info :
