Hi, I’m getting my first experience with lorawan network. The gateway is connected and the node is connected or joined. I see that on TTN console.
The problem is with at+send command after joined…it return an error-1 code. Why?
Hi Avaz,
Can you tell me exactly what parameters you use for the command?
at+send= ???
Also could you make a screenshot of the TTN console, so we can see what packets are received there, should be just the OTAA join request, right ?
Sorry…the hex data array must be on ascii code. I send it as integer on my code.
best regards
SF8. BWD500, wow isn’t that a bit too much
