I am a starter. I already setup a gateway using RAK2245. I have RAK811 modules. How can I use it as a standalone node? Where should I start? As a first step, how can I enable continuous transmission?
Does “standalone node” means no external MCU? If that is the case, you can develop your own firmware or you can do it via RUI https://docs.rakwireless.com/RUI/
Using RUI, you can develop your own continuous transmission node.
