Hi all,
I want to setup a LoRaP2P network on RAK811, region US915.
send “at+mode=1”
got “OK” -
send “at+rf_config=915000000,12,0,1,8,5”
What is correct response after “at+rf_config” ?
Thanks in advance
My Firmware version is RAK811_LF_V2.1.3.4
Hi all,
send “at+mode=1”
got “OK”
Thanks in advance
Hi @msam
For US915 region correct firmware is HF not LF!
After flash with correct firmware the correct response should be OK.
Todor
Hi @msam
Firstly, make sure your RAK811 board is high frequency.
Secondly, download and burn the HF firmware into your RAK811:
https://www.rakwireless.com/en/download/LoRa/RAK811#Firmware_Upgrade
Then do as follow, this is an example which shows LoRa P2P in IN865:
Thanks for reply.I flashed RAK811_HF_V2.0.34.bin
Hi Fomi,
Thanks for feedback.
I flashed HT RAK811_HF_V2.0.3.4.bin firmware.
Now I got an “ERROR-1” message after sending
“at+rfconfig=915000000,8,0,1,8,20”
Hi, @msam
The command is wrong.
at+rf_config=…
BTW, the frequency should not be 915000000 too. You should choose a frequency according to US915 specification:
For example:
at+rf_config=902300000,8,0,1,8,20
Just try again.
