Issue: Jlink Edu Mini can’t connect to RAK815 target. I would like to push a DFU bootloader to nrf52. But I can’t connect to it with the Jlink.Any clue ? Thx, Luc
Setup:RAK815 Jlink Mini EDU SWD connection
Server:
Details:
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] Firmware: J-Link EDU Mini V1 compiled Nov 12 2020 13:31:42
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] Decompressing FW timestamp took 114 us
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] Hardware: V1.00
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] S/N: 801027752
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] OEM: SEGGER
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] Feature(s): FlashBP, GDB
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] TELNET listener socket opened on port 19021
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] WEBSRV Starting webserver
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] WEBSRV Webserver running on local port 19080
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 24.856ms returns “O.K.”
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_HasError()
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_Lock()
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_GetHWStatus(…)
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.308ms returns 0
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_ExecCommand(“SetRestartOnClose = 0”, …).
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.003ms returns 0x01
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_ExecCommand(“DisableFlashDL”, …).
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.004ms returns 0x00
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_ExecCommand(“ExcludeFlashCacheRange 0x0-0xFFFFFFFF”, …).
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.005ms returns 0x00
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_SetHookUnsecureDialog
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_SetHookUnsecureDialog(…)
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.021ms returns 0
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 1.020ms returns 0x00
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_SetSpeed(2000)
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.157ms
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_GetSN()
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.013ms returns 801027752
[2020-Dec-20 22:42:46] [debug] [Backend] - —just_load_core_data
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_ExecCommand(“CORESIGHT_SetIndexAHBAPToUse = 0”, …).
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_ExecCommand(“device = nRF52”, …).
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] XML file found at: /opt/SEGGER/JLink/JLinkDevices.xml
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] /opt/SEGGER/JLink/JLinkDevices.xml evaluated successfully.
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] Device “NRF52” selected.
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 7.951ms returns 0x00
[2020-Dec-20 22:42:46] [debug] [Backend] - read_debug_port_idr
[2020-Dec-20 22:42:46] [debug] [Backend] - read_debug_port_register
[2020-Dec-20 22:42:46] [debug] [Backend] - —just_read_debug_port_register
[2020-Dec-20 22:42:46] [debug] [Backend] - coresight_configure
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_CORESIGHT_Configure()
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 101.416ms returns 0
[2020-Dec-20 22:42:46] [debug] [Backend] - —just_select_debug_port_register
[2020-Dec-20 22:42:46] [debug] [Backend] - Select AP 255, DP Bank 0, AP Bank 255
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 1.968ms returns -1
[2020-Dec-20 22:42:46] [ info] [Backend] - JLinkARM.dll reported “-1”, an unknown error.
[2020-Dec-20 22:42:46] [debug] [Backend] - —just_abort_debug_action
[2020-Dec-20 22:42:46] [ info] [Backend] - Attempting to clear any configuration errors in debug port before closing connection.
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 1.967ms returns -1
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.252ms
[2020-Dec-20 22:42:46] [debug] [ nRF0x0] - close_dll
[2020-Dec-20 22:42:46] [debug] [nRF520x0] - close
[2020-Dec-20 22:42:46] [debug] [Backend] - is_connected_to_emu
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] JLINK_IsOpen()
[2020-Dec-20 22:42:46] [ info] [ JLink] - [Info ] [JLink ] - 0.087ms returns 0x01
[2020-Dec-20 22:42:46] [debug] [Backend] - close
[2020-Dec-20 22:42:46] [debug] [Backend] - disconnect_from_emu
[2020-Dec-20 22:42:46] [debug] [Backend] - —just_disconnect_from_emu
J-Link>st
VTref=3.299V
TCK=0 TDI=0 TDO=0 TMS=0 TRES=1 TRST=?
Supported target interface speeds:
- 96 MHz/n, (n>=24). => 4000kHz, 3840kHz, 3692kHz, …
J-Link>
J-Link>selemu
J-Link[0]: Connection: USB, Serial number: 801027752, ProductName: J-Link EDU Mini
Select emulator index: 0
Disconnecting from J-Link…O.K.
Connecting to J-Link via USB…O.K.
Hardware version: V1.00
S/N: 801027752
License(s): FlashBP, GDB
VTref=3.299V
J-Link>
J-Link>connect
Device “NRF52832_XXAA” selected.
Connecting to target via SWD
InitTarget() start
InitTarget() end
InitTarget() start
InitTarget() end
InitTarget() start
InitTarget() end
InitTarget() start
InitTarget() end
Cannot connect to target.
