Issue:
I am using IAR to program the RAK815. When I do that, I get the following output and it never connects to the gateway.
When I use the already existing hex file for demos. It works fine…
Any help?
Setup:
Server:
Details:
Issue:
Any help?
Server:
Details:
The problem seems to be here, even if I change the application, it does not change.
The “LORAMAC_EVENT_INFO_STATUS_OK” if not confirming…
What should I do?
But when I use the already existing hex files. They work well and it gets connected!
I tried to remove everything an redownload them… not working
