Dear RAK-Fellows,
As always, I am happy about the nice support platform here and I hope you can help me. I have two RPI 3B+ LoRa gateways running on Rak831 and Rak2243. I have followed the latest installation guide:
The Gateways show up nicely on TTN, the signals are forwarded by the gateway and the received signal counter goes up. However, I get no acknowledge for my Adeunis Field Tester device. Using an LP1301 from Dragino, it works but I’d rather go with RAK.
The Gateway also don’t get a GPS fix even though there are clearly GPS modules connected. That’s not such a big issue but the acknowledge error bothers me. Please see the logs for following commands attached:
sudo systemctl status ttn-gateway!
journalctl -f
As well as an image of the Rak2243 gateway.
Best and thank you!
Systemctl:
pi@raspberrypi:~/rak_common_for_gateway $ sudo systemctl status ttn-gateway
? ttn-gateway.service - The Things Network Gateway
Loaded: loaded (/lib/systemd/system/ttn-gateway.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-11-07 15:44:18 GMT; 41s ago
Main PID: 14332 (start.sh)
Tasks: 8 (limit: 2200)
Memory: 1.3M
CGroup: /system.slice/ttn-gateway.service
±14332 /bin/bash /opt/ttn-gateway/packet_forwarder/lora_pkt_fwd/start.sh
±14372 ./lora_pkt_fwd
Nov 07 15:44:56 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:44:57 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:44:59 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:44:59 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:44:59 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:37237028,“chan”:1,“rfch”:1,“freq”:868.300000,“stat”:1,“modu”:“LORA”,“datr”:"
Journalctl -f:
pi@raspberrypi:~/rak_common_for_gateway $ journalctl -f
– Logs begin at Thu 2019-02-14 10:11:59 GMT. –
Nov 07 15:46:27 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:46:27 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:126016324,“chan”:0,“rfch”:1,“freq”:868.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:8.5,“rssi”:-99,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGAAeA61xb1Q=”}]}
Nov 07 15:46:27 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:27 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 68 ms
Nov 07 15:46:29 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:30 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:32 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:33 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:35 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:35 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:46:35 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:134087140,“chan”:1,“rfch”:1,“freq”:868.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:7.8,“rssi”:-101,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGADLsJuvUaE=”}]}
Nov 07 15:46:35 rak-gateway ttn-gateway[14332]: INFO: [down] PULL_ACK received in 79 ms
Nov 07 15:46:35 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 38 ms
Nov 07 15:46:36 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:38 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:39 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:41 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:42 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:42 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:46:44 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:142157980,“chan”:1,“rfch”:1,“freq”:868.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:6.5,“rssi”:-103,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGADRNrW2mTY=”}]}
Nov 07 15:46:44 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:44 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 33 ms
Nov 07 15:46:45 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:45 rak-gateway ttn-gateway[14332]: INFO: [down] PULL_ACK received in 36 ms
Nov 07 15:46:47 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:48 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:50 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:51 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:51 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:46:51 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:150228884,“chan”:1,“rfch”:1,“freq”:868.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:7.8,“rssi”:-103,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGACJCO8fpzU=”}]}
Nov 07 15:46:51 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 35 ms
Nov 07 15:46:53 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: ##### 2019-11-07 15:46:53 GMT #####
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: ### [UPSTREAM] ###
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # RF packets received by concentrator: 5
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # CRC_OK: 80.00%, CRC_FAIL: 20.00%, NO_CRC: 0.00%
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # RF packets forwarded: 4 (92 bytes)
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # PUSH_DATA datagrams sent: 5 (939 bytes)
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # PUSH_DATA acknowledged: 100.00%
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: ### [DOWNSTREAM] ###
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # PULL_DATA sent: 3 (100.00% acknowledged)
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # RF packets sent to concentrator: 0 (0 bytes)
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # TX errors: 0
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # BEACON queued: 0
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # BEACON sent so far: 0
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # BEACON rejected: 0
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: ### [JIT] ###
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # SX1301 time (PPS): 122673899
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: ### [GPS] ###
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # Invalid time reference (age: 1573141613 sec)
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: # no valid GPS coordinates available yet
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: ##### END #####
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: JSON up: {“stat”:{“time”:“2019-11-07 15:46:53 GMT”,“rxnb”:5,“rxok”:4,“rxfw”:4,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Nov 07 15:46:54 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 34 ms
Nov 07 15:46:55 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:55 rak-gateway ttn-gateway[14332]: INFO: [down] PULL_ACK received in 31 ms
Nov 07 15:46:57 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:46:58 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:00 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:00 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:47:00 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:158299692,“chan”:0,“rfch”:1,“freq”:868.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:7.0,“rssi”:-105,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGABkZyIcopQ=”}]}
Nov 07 15:47:00 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 31 ms
Nov 07 15:47:01 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:03 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:04 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:06 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:06 rak-gateway ttn-gateway[14332]: INFO: [down] PULL_ACK received in 73 ms
Nov 07 15:47:07 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:07 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:47:07 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:166370508,“chan”:0,“rfch”:1,“freq”:868.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:7.0,“rssi”:-100,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGADRZKlUOKo=”}]}
Nov 07 15:47:07 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 30 ms
Nov 07 15:47:09 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:10 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:12 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:13 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:15 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:15 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:47:15 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:174441444,“chan”:2,“rfch”:1,“freq”:868.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:7.5,“rssi”:-92,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGAB85RZ8rY8=”}]}
Nov 07 15:47:15 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 31 ms
Nov 07 15:47:16 rak-gateway ttn-gateway[14332]: INFO: [down] PULL_ACK received in 30 ms
Nov 07 15:47:16 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:18 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:19 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:21 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:22 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:182512260,“chan”:1,“rfch”:1,“freq”:868.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:8.8,“rssi”:-99,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGADbZp3qev8=”}]}
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 34 ms
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: INFO: Disabling GPS mode for concentrator’s counter…
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: INFO: host/sx1301 time offset=(1573141460s:482698µs) - drift=-74µs
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: INFO: Enabling GPS mode for concentrator’s counter.
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: ##### 2019-11-07 15:47:23 GMT #####
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: ### [UPSTREAM] ###
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # RF packets received by concentrator: 4
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # RF packets forwarded: 4 (92 bytes)
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # PUSH_DATA datagrams sent: 5 (939 bytes)
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # PUSH_DATA acknowledged: 100.00%
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: ### [DOWNSTREAM] ###
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # PULL_DATA sent: 3 (100.00% acknowledged)
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # RF packets sent to concentrator: 0 (0 bytes)
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # TX errors: 0
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # BEACON queued: 0
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # BEACON sent so far: 0
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # BEACON rejected: 0
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: ### [JIT] ###
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # SX1301 time (PPS): 182674168
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: ### [GPS] ###
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # Invalid time reference (age: 1573141643 sec)
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: # no valid GPS coordinates available yet
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: ##### END #####
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: JSON up: {“stat”:{“time”:“2019-11-07 15:47:23 GMT”,“rxnb”:4,“rxok”:4,“rxfw”:4,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Nov 07 15:47:23 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 30 ms
Nov 07 15:47:25 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:26 rak-gateway ttn-gateway[14332]: INFO: [down] PULL_ACK received in 30 ms
Nov 07 15:47:26 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:28 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:29 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:31 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:31 rak-gateway ttn-gateway[14332]: INFO: Received pkt from mote: D0021105 (fcnt=46037)
Nov 07 15:47:31 rak-gateway ttn-gateway[14332]: JSON up: {“rxpk”:[{“tmst”:190583068,“chan”:1,“rfch”:1,“freq”:868.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:9.0,“rssi”:-103,“size”:23,“data”:“AAURAtB+1bNwZBICAACyGADip5dbyqw=”}]}
Nov 07 15:47:31 rak-gateway ttn-gateway[14332]: INFO: [up] PUSH_ACK received in 31 ms
Nov 07 15:47:32 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:34 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:35 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
Nov 07 15:47:35 rak-gateway ttn-gateway[14332]: INFO: [down] PULL_ACK received in 36 ms
Nov 07 15:47:37 rak-gateway ttn-gateway[14332]: WARNING: [gps] read() returned value 0
