RAK8623 (WisMesh Station HP): RAK13302 PA not engaging at full 1W on meshtasticd 2.7.15
Product: RAK8623 WisMesh Station HP (RAK6421 HAT + RAK13302 1W LoRa module)
Firmware: meshtasticd 2.7.15.48~obsd18f3f7~beta (Debian/meshtasticd apt beta channel)
OS: Raspberry Pi OS Debian 13 (Trixie) 64-bit, custom image (not RAK-provided image)
Firmware version (AT+VER): Not applicable — meshtasticd on Linux does not use AT commands. Version confirmed via apt-cache policy meshtasticd and meshtastic --info (firmwareVersion: "2.7.15").
Source code: No custom firmware. The config.d file referenced below (lora-RAK6421-13302-slot1.yaml) is the official RAK-shipped file included in the meshtasticd beta package, renamed from .disabled to active.
How often: Consistently, across multiple reboots
Background
I am running a custom Trixie image on the RAK8623 with meshtasticd installed from the official beta apt channel. The node is configured as a fixed indoor gateway in Ohio, US915 region. I chose the custom image path deliberately to maintain control over the OS and certificate infrastructure.
Problem
The RAK13302 power amplifier does not appear to be engaging at full 1W (30 dBm). meshtastic --info consistently reports txPower: 30 (requested) but femLnaMode: DISABLED. RF behavior and SNR values from neighboring nodes suggest the node is transmitting at the bare SX1262 ceiling (~22 dBm) rather than the boosted 1W output.
What I have tried
1. meshtasticd 2.7.25 alpha (apt alpha channel)
With the alpha firmware and no config.d file active, the node reported:
  • femLnaMode: NOT_PRESENT
  • hwModel: RAK6421 (correct EEPROM detection)
  • Node ID drifted on every reboot (separate alpha bug)
Enabling the config.d override (lora-RAK6421-13302-slot1.yaml.disabled → active) fixed the gain table but caused hwModel to revert to PORTDUINO and suppressed EEPROM autodetection entirely, also causing node ID drift. Both issues confirmed as alpha firmware bugs.
2. meshtasticd 2.7.15 beta (current)
Downgraded to 2.7.15 beta. Node ID is now stable across reboots. hwModel reports PORTDUINO (expected on Linux). The config.d file lora-RAK6421-13302-slot1.yaml is active and confirmed loading at startup via journalctl:
Jun 22 12:55:02 hostname meshtasticd[1098]: Also using "/etc/meshtasticd/config.d/lora-RAK6421-13302-slot1.yaml" as additional config file
Contents of active config.d file:
Meta:
  name: RAK6421 + RAK13302 Slot 1
  support: official
  compatible:
    - raspberry-pi
Lora:
  Module: sx1262
  IRQ: 22
  Reset: 16
  Busy: 24
  Enable_Pins:
    - 12
    - 13
  DIO3_TCXO_VOLTAGE: true
  DIO2_AS_RF_SWITCH: true
  spidev: spidev0.0
  TX_GAIN_LORA: [9, 9, 10, 11, 9, 8, 9, 10, 10, 10, 11, 12, 12, 12, 12, 12, 12,
12, 12, 10, 9, 8]
Current meshtastic --info output (relevant fields):
"txPower": 30,
"femLnaMode": "DISABLED",
HAT EEPROM is readable at the OS level:
$ cat /proc/device-tree/hat/product
6421 Pi Hat
Question
Is femLnaMode: DISABLED the expected and correct behavior for the RAK13302 on meshtasticd when using Enable_Pins in config.d — meaning the PA is hardware-controlled via those pins and the firmware field is intentionally disabled? Or does DISABLED indicate the PA is not engaging?
A user in an existing thread (RAK6421 + RAK13302 not outputting 1W) reported a similar symptom using pyMC_repeater and suggested a gpioset systemd daemon to hold GPIO 12 and 13 high persistently. Is that workaround also required for meshtasticd users, or should Enable_Pins in config.d be sufficient to engage the PA?
I want to confirm whether I am actually transmitting at 1W before filing this upstream with the Meshtastic project.
More broadly: this is stock, unmodified hardware. What is the correct and complete meshtasticd software stack RAK recommends to achieve reliable 1W output on the RAK8623 with a custom OS image? Is there an official reference configuration — config.d file, systemd services, GPIO setup — that I should be matching?
Thank you.
Just checking in to see if anyone has any suggestions? It seems like the PA still isn’t engaging. My little cheap T1000-E can be seen literally across town, all day, every day, but this high-end WisMesh Station HP (1W) can’t even be seen across the room, let alone down the street. I’m not the only person to be bumping up against this issue.
When this dropped a couple of weeks ago, I built and installed this:
Meshtastic Firmware 2.7.26.54e0d8d Beta
It didn’t change/fix anything but the firmware claims a few things:
Additional *RAK* missing values for 6421 / 13300 13302 modules + Zebra/Nebra Hat Configs by [@Littleaton](https://github.com/Littleaton) in [#10644](https://github.com/meshtastic/firmware/pull/10644)
My gut feeling is, something isn’t detecting the PA hardware, is detecting the chipset only, and locking it in at the 22 dBm max value, not allowing 30 dBm that the PA supports.
I’m in the same boat, not only is the amp not engaging, i think it is actually weakening the power of the radio:
Hi there! Can you run this and share what comes up?
cat /proc/device-tree/hat/custom_1
Meshtastic 2.7.25 alpha allows config overrides, so maybe you didn’t update the EEPROM yet. Follow this guide to set it to 13302 instead: RAK6421 Pi HAT EEPROM Flashing Guide | Write & Verify EEPROM
$ cat /proc/device-tree/hat/custom_1
io_slot1 0
I’ve actually been fairly faithful when using the RAK advanced guide for setting up the WisMesh Station HP. Is there another step I’m missing? And when you say “EEPROM” are you talking about the Meshtastic Firmware, of which I’ve tried four or five different versions, including rolling my own (built from source) of the latest tags… Or is there a separate “EEPROM” that I need to load?
After trying multiple versions of the Meshtastic firmware, this is the one that I built from scratch (as mentioned earlier):
Ahh okay, I see where you’re coming from.
The WisMesh Station HP shipped fully assembled from the factory. I’m assuming it had the latest and greatest EEPROM burned before they shipped it.
 $ which eepmake eepflash.sh eepdump i2cdetect python3
/usr/bin/eepmake
/usr/bin/eepflash.sh
/usr/bin/eepdump
/usr/sbin/i2cdetect
/usr/bin/python3
 $ grep -i i2c /boot/firmware/config.txt
#dtparam=i2c_arm=on
dtparam=i2c_vc=on
dtoverlay=i2c0
 $ i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
  1. Is there a good way to check to see which version of the “RAK6421 Pi HAT EEPROM” is loaded currently?
  2. Where do I obtain the latest version of the “RAK6421 Pi HAT EEPROM”?
Thanks again!
It seems like the EEPROM is in the correct state, because it’s displaying and reporting all of this information:
custom_0: hardware_version D
custom_1: io_slot1 0
custom_2: io_slot2 0
custom_3: sensor_slot_a 0
custom_4: sensor_slot_b 0
custom_5: sensor_slot_c 0
custom_6: sensor_slot_d 0
custom_7: sn [REDACTED]
custom_8: mo WO01-MO2606059494
product: 6421 Pi Hat
product_id: 0x6421
product_ver: 0x0002
uuid: [REDACTED]
vendor: RAK
It’s the EEPROM on the RAK6421 Pi-HAT. Meshtasticd reads the EEPROM to identify what’s on the Pi-HAT—whether it’s a 13300 or a 13302. In the results you shared with me, reading 0 means the Pi-HAT’s EEPROM is not configured correctly (this is also very weird; you’re supposed to read something for io_slot1, not zero. Is yours a VD?check the the version on the HAT pls).
Anyway, you need to use a jumper wire to short the write_enable pins on the HAT. Then, follow this guide: rak6421-hardware-test/EEPROM-FLASHING-GUIDE.md at dev · Sheng2216/rak6421-hardware-test · GitHub.
Just clone the repo to your Pi, and then, in the RAK-6421-eeprom.txt file, uncomment this line: # custom_data "io_slot1 RAK13302". Then, run sudo ./flash-eeprom-and-check.pyto write the info to the EEPROM.
After the EEPROM write is complete, remove the jumper wire, reboot the Pi, and verify using the command cat /proc/device-tree/hat/custom_1. If it outputs something like:
then you should be good to go. You can use the official Meshtastic v2.7.26 (or your custom build, as long as it’s later than the 2.7.15, as the eeprom part is not merged by that time I think) to verify. Good luck! Let me know if it works for you.
Ahh okay, I understand now. To be clear, this unit was shipped, as is, from the factory. The write_enable pins on the HAT have never been touched by me, so the factory shipped this in this poor state, and with the write_enable pins NOT shunted, there’s no way that anything I did could have broken the EEPROM configuration. It shipped like this.
Yes, mine is a VD. Shows LoRa Boost RAK13302_VC on the board.
I shunted the write_enable pins, and wrote a good file with all the settings solid. Rebooted. Now it appears that at least my T1000-E can see it now (from across the room): SNR 9.75dB, RSSI -6dB. These are meaningless numbers, of course, but at least a device across the room can see the RAK. My gut feeling is that I should have higher numbers if the 1W PA is engaged. Is there a way to check that authoritatively?
io_slot1 RAK13302
So I’m better off than where I was before (in that the device is reporting properly)!
I’m currently running v2.7.26.54e0d8d built from scratch. Hopefully that’s the right one?
Also, because, for some reason, the factory-installed GPS (Slot_A) wasn’t seen in the EEPROM, I added that, hopefully correctly. I also added the BME680 module to SLOT_D.
/proc/device-tree/hat $ for f in custom_0 custom_1 custom_2 custom_3 custom_4 custom_5 custom_6; do printf '%s: ' "$f"; cat "$f"; echo; done
custom_1: io_slot1 RAK13302
custom_3: sensor_slot_a RAK12501
custom_6: sensor_slot_d RAK1906
I am mildly concerned that I bought this WishMesh Station HP as a turnkey solution, but the EEPROM information was blank?
