Can you integrate the information transmitted by the RAK9155 on the chirpstak? I can get the rs485 protocol that the RAK9155 is equipped with
Hi @Egodomenico RAK9155 is made to work with WisGate Edge(report in the WebUI) gateways and WisDM. The data is not transmitted over LoRaWAN. We are working on a power solution that will be capable of powering other devices with RAK9155(it will be with POE outputs/12V,5V outputs) and a LoRaWAN module inside that will report the battery status over LoRaWAN.
Have you made any progress on the LoRaWAN enabled battery module?
Did you ever manage to get the data from the RAK9155 without the RS485?
Has it been released?
