Greetings !
I am running the “RAK4630 Battery Level Detect” github repo example using the RAK5005-O baseboard and RAK4630 on the CPU slot.
I need to find some method to differentiate between the external battery voltage and voltage being supplied by the serial USB connection. In the example, the voltage value is being fetched from the WB_A0 analog channel of RAK4630.
From the schematics of baseboard RAK5005-O (CPU Slot) , there are separate pins for checking the external battery voltage and USB voltage as indicated below :
I have confirmed it by using a multi-meter on these pins and it shows me correct voltage for external battery (when connected across Pins 1-3) and also for USB serial voltage (when connected across Pins 7-8).
However, in the following pin mapping between RAK4630/1 and nRF52840, it doesn’t seem possible to single out these CPU slot pins.
* @note RAK4631 GPIO mapping to nRF52840 GPIO ports
RAK4631 <-> nRF52840
WB_IO1 <-> P0.17 (GPIO 17)
WB_IO2 <-> P1.02 (GPIO 34)
WB_IO3 <-> P0.21 (GPIO 21)
WB_IO4 <-> P0.04 (GPIO 4)
WB_IO5 <-> P0.09 (GPIO 9)
WB_IO6 <-> P0.10 (GPIO 10)
WB_SW1 <-> P0.01 (GPIO 1)
WB_A0 <-> P0.04/AIN2 (AnalogIn A2)
WB_A1 <-> P0.31/AIN7 (AnalogIn A7)
Any leads would be appreciated. Thanks.
