Hi Chris,
I setup my RAK7431 node up on in my garage some 30m away with the gateway setup in my house to ensure that the rssi was less than -50 dBm. Unfortunately, this did not resolve my issue with establishing a reliable connection i.e. the result was similar to before in that sometimes the node would connect successfully, but stopped and/or dropped packets as the fcnt was not in sequence.
When not connected, I can see numerous “Accept joint-requests” messages in the ttn device application live data page, so the messages are at least making it that far. When I look at the logs in my Pi Hat RAK2245 gateway, I can see "JSON up: {“rxpk…” and “JSON down: {txpk…” that I think are the node joint request and network server joint accept requests (see below). Thus, I think that the issue is due to my RAK7431 either not receiving or not properly processing the joint accept message from the ttn network server. Uplink and Downlink frequencies look correct for AU915 FSB2.
Edit:
Correction regarding downlink frequency, looking at the syslog in more detail the downlink frequencies from the GW to the Node cover downlink channels 65 to 71.
The only message displayed in the RAK7431 serial interface are “SYSLOG:4:OTAA Join Request” and “EVENT:7:OTAA_FAILED”. I’ve looked trough the RAK7431 documentation, but can find anything that would assist with debugging at the node.
Note:
Just to confirm I don’t have this problem if I configure other nodes e.g. Dragino LT2222, Dragino RS485-ln, RAK811 to name a few.
FROM SYSLOG
Oct 15 17:26:01 rak-gateway ttn-gateway[9187]: JSON down:
“txpk”: {
“imme”: false,
“tmst”: 335281892,
“freq”: 923.9,
“rfch”: 0,
“powe”: 27,
“modu”: “LORA”,
“datr”: “SF10BW500”,
“codr”: “4/5”,
“ipol”: true,
“size”: 33,
“ncrc”: true,
“data”: “IDRzpyYRZSn3OpLb2JXw1oZNdtuStNBXEf4tLyJ2v9cS”
Oct 15 17:26:01 rak-gateway ttn-gateway[9187]: JSON up:
“rxpk”: [{
“tmst”: 330281892,
“chan”: 1,
“rfch”: 0,
“freq”: 917.000000,
“stat”: 1,
“modu”: “LORA”,
“datr”: “SF10BW125”,
“codr”: “4/5”,
“lsnr”: 9.0,
“rssi”: -73,
“size”: 23,
“data”: “ADF0Ffn/CR+sXAkF/v8JH6w4r8XADo4=”
Any suggestions?
If not, I think I’ll park this issue until I can afford to spend more time to resolve the issue.
Kind Regards
Greg
