Replace battery in WisNode Trackit device?
Hi
I have a Wisnode Trackit that has not been used since a while. I wanted to get it back to life but it looks like battery didn’t survive. I putted it in charge 24H but I only get red led when putted on charge. If I try to put it on I have briefly green on the rak button and red on power button and then it goes off again.
Is there a way to open it without destroying it to replace battery ?
Vincèn
No one on this ? I have left the device in charge mode 2 days more but no change so I guess it’s dead or at least battery is dead :frowning:
You can’t replace the battery without braking the enclosure.
And even if you do that, the battery is directly soldered to the PCB through an FPC, if I remember correct, long time since I broke my TrackIt open to get the battery.
thanks @beegee for confirmation it’s not even worth to break to open it :frowning:
