Request RAK811 Breakout Module Board Layout
Hello.
I need Board Layout of Breakout Module.
https://doc.rakwireless.com/datasheet/rakproducts/board-layout---rak811-lora-module
https://doc.rakwireless.com/datasheet/rakproducts/board-layout-rak811-lora-breakout-module
I visited all the above links, but there is no Board Layout of Breakout Module.
Both have only Board Layout of RAK811 Module.
The schematic diagram shows how the connections are made to the pins:
https://doc.rakwireless.com/datasheet/rakproducts/schematic-diagram---rak811-wisduo-lora-module
Is this what you mean?
Can it help you?
Thanks for the answer. But what I asked is the physical size of the breakout module.
Thanks a lot. But what I asked is the physical size of the breakout module.
Thank you for your answer, but I would like to know the distances of the arrows in the picture below.
Sorry, I interpreted board layout as in printed circuit Board Layout and assumed you wanted to know about the connections.
There is the 3D file in the downloads section, you could try that whilst someone from RAK looks at getting you the board dimensions.
