I have a problem in retrieving data from TTN by using Python SDK. I was using python SDK and having a problem. I run the example code from here https://www.thethingsnetwork.org/docs/applications/python/. I have changed the app_id and access_key in that code to my own.
This is the result when I run the code by using Anaconda Prompt:
I think the problem comes from the fact that I did not indicate the path of the certificate in the syntax of the handler:
HandlerClient(app_id, access_key, discovery_address=“discovery.thethings.network:1900”, cert_path="")
In fact, I do not know how to indicate it and even how to obtain this certificate. And this error has a relation with gRPC since I have a windows OS.
Could anyone please help me to solve this issue?
Best regards
