Hi there…
my actual config:
Raspberry 3 B+ / Rak 2247 USB with USB Bridge
OS :RAK2247&RAK833-USB_based_on_Raspbian_OS_for_RPI3_V4.1.0_20191202.zip
if i use the util :
/opt/ttn-gateway/lora_gateway/util_pkt_logger
i capture some Fames:
"B827EBFFFE1D4B80","",“2020-01-02 21:54:49.600Z”, 262148268, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-119,-12.0,"6865697E-FC04468C-13C4"
"B827EBFFFE1D4B80","",“2020-01-02 21:54:52.097Z”, 264646132, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-115,-12.5,"6865697E-BC44468C-13F7"
"B827EBFFFE1D4B80","",“2020-01-02 21:54:54.596Z”, 267144188, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-117,-12.5,"68656C7E-B804768F-92F7"
"B827EBFFFE1D4B80","",“2020-01-02 21:54:57.092Z”, 269642172, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-117,-11.8,"68656C7E-B84446EC-97F7"
"B827EBFFFE1D4B80","",“2020-01-02 21:54:59.594Z”, 272140068, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-117,-12.8,"F8656C6E-F95116EF-9FF1"
"B827EBFFFE1D4B80","",“2020-01-02 21:55:07.087Z”, 279634100, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-115,-11.8,"6865687E-B84416EF-07F4"
"B827EBFFFE1D4B80","",“2020-01-02 21:55:09.586Z”, 282132092, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-117,-11.5,"6865687E-F80446EF-16F4"
"B827EBFFFE1D4B80","",“2020-01-02 21:55:14.582Z”, 287128084, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-119,-12.2,"6865687E-B804768C-13C4"
"B827EBFFFE1D4B80","",“2020-01-02 21:55:17.077Z”, 289625940, 868100000,1, 0,“CRC_BAD”, 10,“LORA”,125000,“SF11” ,“4/5”,-115,-12.5,"6865687E-FC447625-99F4"
… but only with CRC_BAD
if i connected to TTN i see no
Frames from the Device…
i change the Gateway ID from “00000000000000” to :
" gateway_conf": { **
"gateway_ID": "B827EBFFFE1D4B80",**
but nothing happens…
if i use chirpstack… the same… no lora live frames…
only here with the logger… and bad packets…
is the Card defective ?
here the Startup from the Logger:
**root@rak-gateway:/opt/ttn-gateway/lora_gateway/util_pkt_logger# ./util_pkt_logger **
loragw_pkt_logger: INFO: found global configuration file global_conf.json, trying to parse it
loragw_pkt_logger: INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
loragw_pkt_logger: INFO: lorawan_public 1, clksrc 1
loragw_pkt_logger: INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
loragw_pkt_logger: INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
loragw_pkt_logger: INFO: LoRa multi-SF channel 0 enabled, radio 1 selected, IF -400000 Hz, 125 kHz bandwidth, SF 7 to 12
loragw_pkt_logger: INFO: LoRa multi-SF channel 1 enabled, radio 1 selected, IF -200000 Hz, 125 kHz bandwidth, SF 7 to 12
loragw_pkt_logger: INFO: LoRa multi-SF channel 2 enabled, radio 1 selected, IF 0 Hz, 125 kHz bandwidth, SF 7 to 12
loragw_pkt_logger: INFO: LoRa multi-SF channel 3 enabled, radio 0 selected, IF -400000 Hz, 125 kHz bandwidth, SF 7 to 12
loragw_pkt_logger: INFO: LoRa multi-SF channel 4 enabled, radio 0 selected, IF -200000 Hz, 125 kHz bandwidth, SF 7 to 12
loragw_pkt_logger: INFO: LoRa multi-SF channel 5 enabled, radio 0 selected, IF 0 Hz, 125 kHz bandwidth, SF 7 to 12
loragw_pkt_logger: INFO: LoRa multi-SF channel 6 enabled, radio 0 selected, IF 200000 Hz, 125 kHz bandwidth, SF 7 to 12
loragw_pkt_logger: INFO: LoRa multi-SF channel 7 enabled, radio 0 selected, IF 400000 Hz, 125 kHz bandwidth, SF 7 to 12
loragw_pkt_logger: INFO: LoRa standard channel enabled, radio 1 selected, IF -200000 Hz, 250000 Hz bandwidth, SF 7
loragw_pkt_logger: INFO: FSK channel enabled, radio 1 selected, IF 300000 Hz, 125000 Hz bandwidth, 50000 bps datarate
loragw_pkt_logger: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
loragw_pkt_logger: INFO: gateway MAC address is configured to B827EBFFFE1D4B80
loragw_pkt_logger: INFO: found local configuration file local_conf.json, trying to parse it
loragw_pkt_logger: INFO: local_conf.json does not contain a JSON object named SX1301_conf
loragw_pkt_logger: INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
loragw_pkt_logger: INFO: concentrator started, packet can now be received
loragw_pkt_logger: INFO: Now writing to log file pktlog_B827EBFFFE1D4B80_20200102T215030Z.csv
have you some suggestions ?
BR
Fritze
