Hello all,
Is there a way to select the subband for LoRaWAN use on the US915 band?
Hello all,
You can use either AT+CHE or AT+MASK.
If you are using the default TTN or Helium sub-band, you can try AT+MASK=0002 or AT+CHE=2.
If via API,
uint16_t maskBuff = 0x0002;
api.lorawan.mask.set(&maskBuff);
Thank you for your response carlrowan,
To confirm, if I for example wanted to use US915 subband 5, I would set the maskBuff to 0x0005 with the API?
It should be 0x0010.
2 = 0x0002
3 = 0x0004
4 = 0x0008
5 = 0x0010
Excellent, just what I needed. Thank you!
