Dear Sir, plase send me WinSCP user name and PSW
i use RAK811 node
and GW:7244C
i use RAK811 node
and GW:7244C
Hi, you may want to check the latest RUI compiler here build.rakwireless.com
More info here: RUI
And the Git with the code is here.
Dear Sir,
I used Git RAK811 Code which you Share link I Compile the code and Upload in RAK811 Module. but it Did not Print anything in the Serial Terminal. I use Hercules Serial Terminal.
How can I Check Code is Workin or Not? How Can I Put Sleep Mode Rak811 Module?
please Help Me.
Am… please use our serial tool. This tool that you use has limited options. You need to send \r\n at the end of the AT commands to be recognized.
Dear Sir,
please share your mail id. here is .zip fill upload problem.
More info here: RUI
i share you above link where i download code and compile online.
i used RAK811 breakboard.
i face code compile problem.
Also, please do not double post topics!
thanks to help me. i used DFU tool for upgrade latest version
