What product do you wish to discuss? RAK4631, RAK3372, RAK11200, RAK11310, RAK11722?
RAK11720 -
What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)?
RUI3 V 4.1.1 -
What firmware version? Can it be obtained with AT+VER=?
AT+VER=RUI_4.1.1_RAK11720 -
Computer OS? (MacOS, Linux, Windows)
Linux -
What Computer OS version?
Ubuntu 24.04 LTS -
How often does the problem happen?
Adding multicast to ABP Sample -
How can we replicate the problem?
Take example Lorawan_ABP and add
/**Setting multicast seccion */
uint8_t assigned_dev_addr[4] = {0};
Serial.printf(“Device Address is %02X%02X%02X%02X\r\n”, assigned_dev_addr[0], assigned_dev_addr[1], assigned_dev_addr[2], assigned_dev_addr[3]); // Check Device Address
memcpy(session.McAppSKey, node_mc_AppSKey, 16);
memcpy(session.McNwkSKey, node_mc_NwkSKey, 16);
session.McAddress = assigned_dev_addr[0] << 24 | assigned_dev_addr[1] << 16 | assigned_dev_addr[2] << 8 | assigned_dev_addr[3];//LoRaWAN Multicast Setting
if(api.lorawan.addmulc(session) == true) {
Serial.println(“Add Multicast Success”);
} else {
Serial.println(“Add Multicast Fail”);
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
- This example shows LoRaWan protocol joining the network in ABP mode, class A, region US915.
- Device will send uplink every 5 seconds.
#define ABP_PERIOD (5000)
LoRaWAN band setting:
RAK_REGION_EU433
RAK_REGION_CN470
RAK_REGION_RU864
RAK_REGION_IN865
RAK_REGION_EU868
RAK_REGION_US915
RAK_REGION_AU915
RAK_REGION_KR920
RAK_REGION_AS923
#define ABP_BAND (RAK_REGION_US915)
#define ABP_DEVADDR {0x26, 0x0C, 0xFA, 0x55}
#define ABP_APPSKEY {0x45,0x53,0x43,0x2d,0x67,0x72,0x6f,0x75,0x70,0x20,0x4e,0x61,0x69,0x61,0x14,0x17}
#define ABP_NWKSKEY {0x45,0x53,0x43,0x2d,0x67,0x72,0x6f,0x75,0x70,0x20,0x4e,0x61,0x69,0x61,0x14,0x18}
uint16_t maskChannel = 0x0002;
//LoRaWan Multicast Session
uint8_t node_mc_address[4] = {0x01, 0x02, 0x03, 0x04};
uint8_t node_mc_AppSKey[16] = {0x45,0x53,0x43,0x2d,0x67,0x72,0x6f,0x75,0x70,0x20,0x4e,0x61,0x69,0x61,0x14,0x18};
uint8_t node_mc_NwkSKey[16] = {0x45,0x53,0x43,0x2d,0x67,0x72,0x6f,0x75,0x70,0x20,0x4e,0x61,0x69,0x61,0x14,0x18};
RAK_LORA_McSession session = {
.McDevclass = 2,
.McAddress = node_mc_address[0]<<24 | node_mc_address[1]<<16 | node_mc_address[2]<<8 | node_mc_address[3],
.McFrequency = 923300000,
.McDatarate = 8,
.McPeriodicity = 0,
.McGroupID = 2,
.entry = 0,
/** Packet buffer for sending */
uint8_t collected_data[64] = { 0 };
void recvCallback(SERVICE_LORA_RECEIVE_T * data)
if (data->BufferSize > 0) {
Serial.println(“Something received!”);
Serial.printf(“%x”, data->Buffer[i]);
Serial.print(“\r\n”);
- enum type for LoRa Event
RAK_LORAMAC_STATUS_OK = 0,
RAK_LORAMAC_STATUS_ERROR,
RAK_LORAMAC_STATUS_TX_TIMEOUT,
RAK_LORAMAC_STATUS_RX1_TIMEOUT,
RAK_LORAMAC_STATUS_RX2_TIMEOUT,
RAK_LORAMAC_STATUS_RX1_ERROR,
RAK_LORAMAC_STATUS_RX2_ERROR,
RAK_LORAMAC_STATUS_JOIN_FAIL,
RAK_LORAMAC_STATUS_DOWNLINK_REPEATED,
RAK_LORAMAC_STATUS_TX_DR_PAYLOAD_SIZE_ERROR,
RAK_LORAMAC_STATUS_DOWNLINK_TOO_MANY_FRAMES_LOSS,
RAK_LORAMAC_STATUS_ADDRESS_FAIL,
RAK_LORAMAC_STATUS_MIC_FAIL,
RAK_LORAMAC_STATUS_MULTICAST_FAIL,
RAK_LORAMAC_STATUS_BEACON_LOCKED,
RAK_LORAMAC_STATUS_BEACON_LOST,
RAK_LORAMAC_STATUS_BEACON_NOT_FOUND,
if (status == RAK_LORAMAC_STATUS_OK) {
Serial.println(“Successfully sent”);
} else {
Serial.println(“Sending failed”);
void setup()
Serial.begin(115200, RAK_AT_MODE);
delay(2000);
Serial.println("RAKwireless LoRaWan ABP Example");
if(api.lorawan.nwm.get() != 1)
Serial.printf("Set Node device work mode %s\r\n",
api.lorawan.nwm.set() ? "Success" : "Fail");
api.system.reboot();
// ABP Device Address MSB first
uint8_t node_dev_addr[4] = ABP_DEVADDR;
// ABP Application Session Key
uint8_t node_app_skey[16] = ABP_APPSKEY;
// ABP Network Session Key
uint8_t node_nwk_skey[16] = ABP_NWKSKEY;
if (!api.lorawan.njm.set(RAK_LORA_ABP)) // Set the network join mode to ABP
Serial.printf("LoRaWan ABP - set network join mode is incorrect! \r\n");
return;
if (!api.lorawan.daddr.set(node_dev_addr, 4)) {
Serial.printf("LoRaWan ABP - set device addr is incorrect! \r\n");
return;
if (!api.lorawan.appskey.set(node_app_skey, 16)) {
Serial.printf("LoRaWan ABP - set application session key is incorrect! \r\n");
return;
if (!api.lorawan.nwkskey.set(node_nwk_skey, 16)) {
Serial.printf("LoRaWan ABP - set network session key is incorrect! \r\n");
return;
if (!api.lorawan.band.set(ABP_BAND)) {
Serial.printf("LoRaWan ABP - set band is incorrect! \r\n");
return;
if (!api.lorawan.deviceClass.set(RAK_LORA_CLASS_A)) {
Serial.printf("LoRaWan ABP - set device class is incorrect! \r\n");
return;
if (!api.lorawan.adr.set(true)) {
Serial.printf("LoRaWan ABP - set adaptive data rate is incorrect! \r\n");
return;
if (!api.lorawan.rety.set(1)) {
Serial.printf("LoRaWan ABP - set retry times is incorrect! \r\n");
return;
if (!api.lorawan.cfm.set(1)) {
Serial.printf("LoRaWan ABP - set confirm mode is incorrect! \r\n");
return;
Serial.printf("Device Address is %02X%02X%02X%02X\r\n", assigned_dev_addr[0], assigned_dev_addr[1], assigned_dev_addr[2], assigned_dev_addr[3]); // Check Device Address
Serial.println("Add Multicast Success");
} else {
Serial.println("Add Multicast Fail");
/** Check LoRaWan Status*/
Serial.printf("Duty cycle is %s\r\n", api.lorawan.dcs.get()? "ON" : "OFF"); // Check Duty Cycle status
Serial.printf("Packet is %s\r\n", api.lorawan.cfm.get()? "CONFIRMED" : "UNCONFIRMED"); // Check Confirm status
// uint8_t assigned_dev_addr[4] = { 0 };
Serial.printf("Uplink period is %ums\r\n", ABP_PERIOD);
Serial.println("");
void uplink_routine()
/** Payload of Uplink */
uint8_t data_len = 0;
collected_data[data_len++] = (uint8_t) ‘t’;
collected_data[data_len++] = (uint8_t) ‘e’;
collected_data[data_len++] = (uint8_t) ‘s’;
Serial.println("Data Packet:");
for (int i = 0; i < data_len; i++) {
Serial.printf("0x%02X ", collected_data[i]);
Serial.println("");
/** Send the data package */
if (api.lorawan.send(data_len, (uint8_t *) & collected_data, 2, true, 1)) {
Serial.println("Sending is requested");
} else {
Serial.println("Sending failed");
void loop()
static uint64_t last = 0;
static uint64_t elapsed;
if ((elapsed = millis() - last) > ABP_PERIOD) {
uplink_routine();
last = millis();
//Serial.printf("Try sleep %ums..", ABP_PERIOD);
api.system.sleep.all(ABP_PERIOD);
//Serial.println("Wakeup..");
Console output adding multicast
Device Address is 260CFA55
Add Multicast Fail
Duty cycle is ON
Packet is CONFIRMED
Uplink period is 5000ms
Current Work Mode: LoRa P2P.
Data Packet:
0x74 0x65 0x73 0x74
Sending failed
Data Packet:
0x74 0x65 0x73 0x74
Sending failed
without multicast code
Duty cycle is ON
Packet is CONFIRMED
Current Work Mode: LoRaWAN.
Data Packet:
0x74 0x65 0x73 0x74
Successfully sent
