is there a more detailed list with explanations for all the error codes?
e.g, I get +EVT:SEND_CONFIRMED_FAILED(4) or +EVT:JOIN_FAILED_7 and sometimes others.
What do the numbers mean and how can I use it to improve the product?
These numbers are based on the LoRaMAC stack event status and are very basic information:
/**@par Description
* The LoRaMac Event Info
typedef enum RAKLoRaMacEventInfoStatus
RAK_LORAMAC_STATUS_OK = 0, ///Service performed successfully
RAK_LORAMAC_STATUS_ERROR, ///An error occurred during the execution of the service
RAK_LORAMAC_STATUS_TX_TIMEOUT, ///A Tx timeout occurred
RAK_LORAMAC_STATUS_RX1_TIMEOUT, ///An Rx timeout occurred on receive window 1
RAK_LORAMAC_STATUS_RX2_TIMEOUT, ///An Rx timeout occurred on receive window 2
RAK_LORAMAC_STATUS_RX1_ERROR, ///An Rx error occurred on receive window 1
RAK_LORAMAC_STATUS_RX2_ERROR, ///An Rx error occurred on receive window 2
RAK_LORAMAC_STATUS_JOIN_FAIL, ///An error occurred in the join procedure
RAK_LORAMAC_STATUS_DOWNLINK_REPEATED, ///A frame with an invalid downlink counter was received. The downlink counter of the frame was equal to the local copy of the downlink counter of the node.
RAK_LORAMAC_STATUS_TX_DR_PAYLOAD_SIZE_ERROR, ///The MAC could not retransmit a frame since the MAC decreased the datarate. The payload size is not applicable for the datarate.
RAK_LORAMAC_STATUS_DOWNLINK_TOO_MANY_FRAMES_LOSS, ///The node has lost MAX_FCNT_GAP or more frames.
RAK_LORAMAC_STATUS_ADDRESS_FAIL, ///An address error occurred
RAK_LORAMAC_STATUS_MIC_FAIL, ///Message integrity check failure
RAK_LORAMAC_STATUS_MULTICAST_FAIL, ///Multicast error occurred
RAK_LORAMAC_STATUS_BEACON_LOCKED, ///Beacon locked
RAK_LORAMAC_STATUS_BEACON_LOST, ///Beacon lost
RAK_LORAMAC_STATUS_BEACON_NOT_FOUND, ///Beacon not found
}RAKLoRaMacEventInfoStatus_t;
+EVT:SEND_CONFIRMED_FAILED(4) means there was no ACK received from the LNS in RX1 and RX2 window. +EVT:JOIN_FAILED_7 means that JOIN failed because the device didn’t receive a JOIN accept package from the LNS.
It will not help you much unless you add in addition packet logs from your gateway and logs from the LNS to check what went wrong.
