Hi BeeGee,
I’m trying out a relay firmware for RUI3. The code loads correctly and receives the data but it doesn’t do what I want when I send it a download link from chirpstack V4
I’ve already tried to convert to base64 for chirpstack V4 and it doesn’t work. I used another test code and the relay turns off and on every 5 seconds without any problem
void setup() {
pinMode(WB_IO2, OUTPUT);
digitalWrite(WB_IO2, HIGH);
pinMode(WB_IO4, OUTPUT);
// Initialize serial for output.
void loop() {
digitalWrite(WB_IO4, LOW);
delay(5000);
digitalWrite(WB_IO4, HIGH);
delay(5000);
Can you tell me if the download link is correct or if I’m missing something that I’m not seeing?
