In the RUI3 docs the TXPower for US915 is described as:
- Is MaxEIRP = 22dBm? or is it 30dBm?
- For TXPower 3 to 9 the configuration would be as follows? or there’s no support for those TXPower values?
TXPower—Configuration
3--------------MaxEIRP - 6dB
4--------------MaxEIRP - 8dB
5--------------MaxEIRP -10dB
6--------------MaxEIRP - 12dB
7--------------MaxEIRP - 14dB
8--------------MaxEIRP - 16dB
9--------------MaxEIRP - 18dB
- If MaxEIRP = 30dBm and the above table is correct, then the Conducted Power for TXPower = 0-4 is 22dBm?
Thanks.
carlrowan
(Carl Rowan)
2
Hi @nicolasech ,
You are correct. For LoRaWAN mode, the TXPower will be clipped to 22dB as stated on LoRaWAN Specification.
Hi @carlrowan,
Thanks for your reply, based on it I’ll assume:
MaxEIRP is 30dBm, but the module will clip the output power to 22dBm.
The above table is correct
The above is correct
carlrowan
(Carl Rowan)
4
Yes, that’s correct @nicolasech
system
(system)
Closed
5
