Hi. I heard that the min power consumption in Rx windows at RAK811 is 5.5mA, but I just can’t figure out how can we reach that level. currently with at command (at+rxc=1), I measure 21mA in Rx mode which is too high. any suggestion on how decreasing power consumption?
Hi @illia,
What is your setup - how are you measuring the power consumption. Are you using the RAK811 with the breakout board, the wis node, etc.
Please give us some more info
Thanks for reply
I’m just using single RAK811 module. I put RAK811 in Rx continuous mode (at+rxc=1) with default setup (EU868) and as it said in datasheet, the min power consumption in Rx mode is 5.5mA., but I measure 21mA steady. I wanna know how can i decrease it down? any particular peripheral which i should turn it off? Should I dig in the code or any AT command which can help me?
