Yes i use mosquitto_sub:
mosquitto_sub -t "application/3/#" -v
application/3/device/60c5456789ec7/rx {"applicationID":"3","applicationName":"sondehumtemp","deviceName":"node01","devEUI":"YMWo//54P8c=",
"rxInfo":[{"gatewayID":"3KY123456=","time":"2020-05-09T09:15:24.313107Z","timeSinceGPSEpoch":"1273050941.313s","rssi":-53,"loRaSNR":8,"channel":2,"rfChain":1,"board":0,"antenna":0,"location":{"latitude":0,"longitude":0,"altitude":0,"source":"UNKNOWN","accuracy":0},"fineTimestampType":"NONE","context":"d+GjNA==","uplinkID":"qZLyA4YOTOG6zkNcAp6kBw==","crcStatus":"CRC_OK"}],
"txInfo":{"frequency":868500000,"modulation":"LORA","loRaModulationInfo":{"bandwidth":125,"spreadingFactor":12,"codeRate":"4/5","polarizationInversion":false}},
"adr":true,
"dr":0,
"fCnt":1221,
"fPort":8,
"data":"CAIBbgdoawZzJbcCZwCvBAIDvQ==",
"objectJSON":"{\"barometer\":965.5,\"battery\":3.66,\"gasResistance\":9.57,\"humidity\":53.5,\"temperature\":17.5}","tags":{}}
Maybe i use a old Chirpstack version?
chirpstack-application-server version : 3.10.0
chirpstack-network-server version : 3.9.0
chirpstack-gateway-bridge version : 3.8.0
The script for payload decode is:
// Decode decodes an array of bytes into an object.
// - fPort contains the LoRaWAN fPort number
// - bytes is an array of bytes, e.g. [225, 230, 255, 0]
// The function must return an object, e.g. {"temperature": 22.5}
function Decode(fPort, bytes) {
var decoded = {};
var hexString=bin2HexStr(bytes);
return rakSensorDataDecode(hexString);
// convert array of bytes to hex string.
// e.g: 0188053797109D5900DC140802017A0768580673256D0267011D040214AF0371FFFFFFDDFC2E
function bin2HexStr(bytesArr) {
var str = "";
for(var i=0; i<bytesArr.length; i++) {
var tmp = (bytesArr[i] & 0xff).toString(16);
if(tmp.length == 1) {
tmp = "0" + tmp;
str += tmp;
return str;
// convert string to short integer
function parseShort(str, base) {
var n = parseInt(str, base);
return (n << 16) >> 16;
// convert string to triple bytes integer
function parseTriple(str, base) {
return (n << 8) >> 8;
// decode Hex sensor string data to object
function rakSensorDataDecode(hexStr) {
var str = hexStr;
var myObj = {};
while (str.length > 4) {
var flag = parseInt(str.substring(0, 4), 16);
switch (flag) {
case 0x0768:// Humidity
myObj.humidity = parseFloat(((parseShort(str.substring(4, 6), 16) * 0.01 / 2) * 100).toFixed(1));//unit:%RH
str = str.substring(6);
break;
case 0x0673:// Atmospheric pressure
myObj.barometer = parseFloat((parseShort(str.substring(4, 8), 16) * 0.1).toFixed(2)); //unit:hPa
str = str.substring(8);
break;
case 0x0267:// Temperature
myObj.temperature = parseFloat((parseShort(str.substring(4, 8), 16) * 0.1).toFixed(2));//unit: °C
break;
case 0x0188:// GPS
myObj.latitude = parseFloat((parseTriple(str.substring(4, 10), 16) * 0.0001).toFixed(4)) + "°";//unit:°
myObj.longitude = parseFloat((parseTriple(str.substring(10, 16), 16) * 0.0001).toFixed(4)) + "°";//unit:°
myObj.altitude = parseFloat((parseTriple(str.substring(16, 22), 16) * 0.01).toFixed(1)) + "m";//unit:m
str = str.substring(22);
break;
case 0x0371:// Triaxial acceleration
myObj.acceleration_x = parseFloat((parseShort(str.substring(4, 8), 16) * 0.001).toFixed(3)) + "g";//unit:g
myObj.acceleration_y = parseFloat((parseShort(str.substring(8, 12), 16) * 0.001).toFixed(3)) + "g";//unit:g
myObj.acceleration_z = parseFloat((parseShort(str.substring(12, 16), 16) * 0.001).toFixed(3)) + "g";//unit:g
str = str.substring(16);
break;
case 0x0402:// air resistance
myObj.gasResistance = parseFloat((parseShort(str.substring(4, 8), 16) * 0.01).toFixed(2)) ;//unit:KΩ
break;
case 0x0802:// Battery Voltage
myObj.battery = parseFloat((parseShort(str.substring(4, 8), 16) * 0.01).toFixed(2)) ;//unit:V
break;
case 0x0586:// gyroscope
myObj.gyroscope_x = parseFloat((parseShort(str.substring(4, 8), 16) * 0.01).toFixed(2)) + "°/s";//unit:°/s
myObj.gyroscope_y = parseFloat((parseShort(str.substring(8, 12), 16) * 0.01).toFixed(2)) + "°/s";//unit:°/s
myObj.gyroscope_z = parseFloat((parseShort(str.substring(12, 16), 16) * 0.01).toFixed(2)) + "°/s";//unit:°/s
break;
case 0x0902:// magnetometer x
myObj.magnetometer_x = parseFloat((parseShort(str.substring(4, 8), 16) * 0.01).toFixed(2)) + "μT";//unit:μT
break;
case 0x0a02:// magnetometer y
myObj.magnetometer_y = parseFloat((parseShort(str.substring(4, 8), 16) * 0.01).toFixed(2)) + "μT";//unit:μT
break;
case 0x0b02:// magnetometer z
myObj.magnetometer_z = parseFloat((parseShort(str.substring(4, 8), 16) * 0.01).toFixed(2)) + "μT";//unit:μT
break;
default:
str = str.substring(7);
break;
return myObj;
