I’m using the WisBlock Microphone Starter Kit LoRa/BLE with Arduino. I have mounted an SD card on the board following example on RAK15002: RAK15002 Quick Start Guide | RAKwireless Documentation Center
When running the sketch, I get “Card Mount Failed! Please make sure the card is inserted!”. I have tested two different SD cards and I have also tested those cards on an arduino and confirmed that both work fine.
Does the RAK18003 require different configurations to use an SD card?
