Issue: Need help to connect my sensors
Setup:
Sensor => Milesigth EM300-TH-868M
Converter => KNX/LoRaWAN-Converter HD67D27-B2-868MHz
LoRa® Server: RAK 7258
Details: I want to connect the Sensor for temperature and humidity. In the Gateway I have create a Application and add the sensor. In the Page “Live Device Data” i can see the values they come in. In the meantime i was able to add the Converter to the Gateway. Now are two devices are connected to the gateway.
I ask the vendor of the converter and he reply: " To make the connection between your LoRaWAN device and ours, you must first create the payload association in your gateway. Once this is done, you can go to our device to indicate the number of bytes you want to go to. "
I am a beginner in LoRa and I am not understand how i can do that what the support of the vendor describe. Can someone assist me?
