Sensor to Relay
Hello !!!
I’m using RAK11720 and i want that the module sends data to the relay module, so that the relay forwards it to the server, is it possible with RAK11720 ? and if yes, how to do it ?
Welcome to the forum @Jostin
The RAK11720 with RUI3 does not support relay mode.
However, if you have another node, that supports relay mode, the RAK11720 should be able to communicate through the relay node to a gateway.
We did not look into the way relay nodes are working, but the RAK11720 should not need to know if there are relay nodes.
But we never tested it.
I’ve another node that supports relay mode, so, how can i do so that the RAK11720 communicates through the relay node to a gateway ?
