I have a RAK4631 core and a RAK19010 base. I’m trying to send a “Hello World” message to the platformio monitor. I am able to use the RAKDAP1 to flash to the RAK4631 but I am unable to receive serial print statements in the platformio monitor. My current code is as follows (ignore the RS485 and modbus library imports those are for future use):
#include <Arduino.h>
#include "Adafruit_TinyUSB.h"
#include <ArduinoRS485.h>
#include <ArduinoModbus.h>
void setup()
pinMode(LED_BUILTIN, OUTPUT);
Serial1.begin(115200);
void loop()
delay(1000);
delay(1000);
Serial1.println("Hello World");
Building the file receives no errors but when I click Upload or Upload and Monitor I get the following log:
Processing MODBUS (board: wiscore_rak4631; platform: nordicnrf52; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/wiscore_rak4631.html
PLATFORM: Nordic nRF52 (10.4.0) > WisCore RAK4631 Board
HARDWARE: NRF52840 64MHz, 243KB RAM, 796KB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, stlink)
PACKAGES:
- framework-arduinoadafruitnrf52 @ 1.10600.0 (1.6.0)
- framework-cmsis @ 2.50700.210515 (5.7.0)
- tool-adafruit-nrfutil @ 1.503.0 (5.3)
- tool-bossac-nordicnrf52 @ 1.10901.201022 (1.9.1)
- tool-openocd @ 3.1200.0 (12.0)
- tool-sreccat @ 1.164.0 (1.64)
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 15 compatible libraries
Scanning dependencies...
Dependency Graph
|-- ArduinoModbus @ 1.0.9
|-- Adafruit TinyUSB Library
|-- ArduinoRS485 @ 1.0.5
Building in release mode
Checking size .pio\build\MODBUS\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [ ] 3.0% (used 7480 bytes from 248832 bytes)
Flash: [= ] 5.5% (used 44772 bytes from 815104 bytes)
Configuring upload protocol...
AVAILABLE: cmsis-dap, jlink, nrfjprog, nrfutil, stlink
CURRENT: upload_protocol = cmsis-dap
Uploading .pio\build\MODBUS\firmware.hex
xPack Open On-Chip Debugger 0.12.0-01004-g9ea7f3d64-dirty (2023-01-30-15:04)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 1
[nrf52.cpu] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x00000a80 msp: 0x20000400
** Programming Started **
Warn : Adding extra erase range, 0x00030ee4 .. 0x00030fff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
======================= [SUCCESS] Took 6.37 seconds =======================
* Terminal will be reused by tasks, press any key to close it.
* Executing task in folder RDTM: C:\Users\lukaj\.platformio\penv\Scripts\platformio.exe run --target upload --environment MODBUS
PACKAGES:
Dependency Graph
RAM: [ ] 3.1% (used 7820 bytes from 248832 bytes)
Flash: [= ] 5.8% (used 46992 bytes from 815104 bytes)
debug_level: 1
Warn : Adding extra erase range, 0x00031790 .. 0x00031fff
** Verified OK **
======================= [SUCCESS] Took 6.53 seconds =======================
type or paste code here
I’m not sure if this will point to the issue or not. chasing the "[nrf52.cpu] halted due to debug-request, current mode: Thread " line hasn’t lead to anything beneficial yet.
I have tried all variations of Serial, Serial1, and Serial2. I have the U_TX and U_RX pins of the RAKDAP1 connected to the TX0 and RX0 pins on the board. Swapping the connections doesn’t change anything. I have used a voltmeter and tested continuity between both the soldered TX0 and RX0 pins and the corresponding UART1_TX and UART1_RX pins on the RAK4631. When I accidentally touched the RX pin on the RAKDAP1 to RS485-B pin on my RAK5802 module random symbols appeared on the platformio monitor so I’m assuming that it is possible to achieve what I want, I’m just unsure how. Any pointers would be greatly appreciated.
