Dear all,
When rak811 send data to rak2247 i received such as
at+recv=0,-44,30,0:
Both in unconfirmed and confirmed send. But it is different with response
[LoRa]: RUI_MCPS_UNCONFIRMED send success
OK
or
[LoRa]: RUI_MCPS_CONFIRMED send success
OK
I had a question at+recv=0,-44,30,0: is ack from server chirpstack to node? If it is correct then what is different between 2 these modes?
A confirmed send is when the network server confirms it got the message. Remembering that the gateway is just a conduit, you have no idea if any gateway heard your message without a confirmation, however there are considerable disadvantages to bandwidth if you always send a message with a confirmation request. Some level of ‘intelligence’ can be built in to the device to check it is being heard by sending a message with confirmation on at appropriate intervals and if no ACK comes back, trying a join again.
As for the response that you are getting at the moment, do you have ADR turned on as you may be receiving other commands from the server.
