Hi guys,
So after flashing the firmware and installing the LORIOT software I now get this read out from the system log:
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # PULL_DATA sent: 6 (100.00 acknowledged)
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # TX errors: 0
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # BEACON queued: 0
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # BEACON sent so far: 0
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # BEACON rejected: 0
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: ### [JIT] ###
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # SX1301/SX1302 time (PPS): 0, offset us 0
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: ### [GPS] ###
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: # GPS sync is disabled
Thu Sep 30 15:40:43 2021 user.notice lora_pkt_fwd[2159]: ##### END #####
Thu Sep 30 15:40:46 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:40:46 2021 kern.info quectel-CM[11862]: Dail Failed 12
Thu Sep 30 15:40:51 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:40:51 2021 kern.info quectel-CM[11862]: Dail Failed 13
Thu Sep 30 15:40:56 2021 daemon.info dnsmasq-dhcp[2674]: DHCPREQUEST(br-lan) 192.168.230.104 38:ba:f8:22:a8:b2
Thu Sep 30 15:40:56 2021 daemon.info dnsmasq-dhcp[2674]: DHCPACK(br-lan) 192.168.230.104 38:ba:f8:22:a8:b2 uea5cg8357nmb
Thu Sep 30 15:40:56 2021 daemon.warn odhcpd[1646]: DHCPV6 SOLICIT IA_NA from 00010001234e33ddf43909803d6f on br-lan: ok fdda:d154:735::9ea/128
Thu Sep 30 15:40:56 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:40:56 2021 kern.info quectel-CM[11862]: Dail Failed 14
Thu Sep 30 15:40:57 2021 daemon.info dnsmasq-dhcp[2674]: DHCPREQUEST(br-lan) 192.168.230.104 38:ba:f8:22:a8:b2
Thu Sep 30 15:40:57 2021 daemon.info dnsmasq-dhcp[2674]: DHCPACK(br-lan) 192.168.230.104 38:ba:f8:22:a8:b2 uea5cg8357nmb
Thu Sep 30 15:40:57 2021 daemon.warn odhcpd[1646]: DHCPV6 SOLICIT IA_NA from 00010001234e33ddf43909803d6f on br-lan: ok fdda:d154:735::9ea/128
Thu Sep 30 15:40:58 2021 daemon.info dnsmasq-dhcp[2674]: DHCPREQUEST(br-lan) 192.168.230.104 38:ba:f8:22:a8:b2
Thu Sep 30 15:40:58 2021 daemon.info dnsmasq-dhcp[2674]: DHCPACK(br-lan) 192.168.230.104 38:ba:f8:22:a8:b2 uea5cg8357nmb
Thu Sep 30 15:40:58 2021 daemon.warn odhcpd[1646]: DHCPV6 SOLICIT IA_NA from 00010001234e33ddf43909803d6f on br-lan: ok fdda:d154:735::9ea/128
Thu Sep 30 15:40:59 2021 daemon.warn odhcpd[1646]: DHCPV6 REQUEST IA_NA from 00010001234e33ddf43909803d6f on br-lan: ok fdda:d154:735::9ea/128
Thu Sep 30 15:40:59 2021 daemon.info dnsmasq[2674]: read /etc/hosts - 1 addresses
Thu Sep 30 15:40:59 2021 daemon.info dnsmasq[2674]: read /tmp/hosts/dhcp - 1 addresses
Thu Sep 30 15:40:59 2021 daemon.info dnsmasq[2674]: read /tmp/hosts/odhcpd - 1 addresses
Thu Sep 30 15:40:59 2021 daemon.info dnsmasq-dhcp[2674]: read /etc/ethers - 0 addresses
Thu Sep 30 15:41:01 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:01 2021 kern.info quectel-CM[11862]: Dail Failed 15
Thu Sep 30 15:41:07 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:07 2021 kern.info quectel-CM[11862]: Dail Failed 16
Thu Sep 30 15:41:12 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:12 2021 kern.info quectel-CM[11862]: Dail Failed 17
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]:
2021-09-30 15:41:13 UTC
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: ### [UPSTREAM] ###
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # RF packets received by concentrator: 0
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # PUSH_DATA datagrams sent: 1 (135 bytes)
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # PUSH_DATA acknowledged: 100.00
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: ### [DOWNSTREAM] ###
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # PULL_DATA sent: 6 (100.00 acknowledged)
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # SX1301/SX1302 time (PPS): 0, offset us 0
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: ### [GPS] ###
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: # GPS sync is disabled
Thu Sep 30 15:41:13 2021 user.notice lora_pkt_fwd[2159]: ##### END #####
Thu Sep 30 15:41:17 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:17 2021 kern.info quectel-CM[11862]: Dail Failed 18
Thu Sep 30 15:41:19 2021 daemon.info bufwr[2005]: bufwrInit Done.
Thu Sep 30 15:41:22 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:22 2021 kern.info quectel-CM[11862]: Dail Failed 19
Thu Sep 30 15:41:27 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:27 2021 kern.info quectel-CM[11862]: Dail Failed 20
Thu Sep 30 15:41:29 2021 daemon.info db[2005]: DataBase Backup
Thu Sep 30 15:41:32 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:32 2021 kern.info quectel-CM[11862]: Dail Failed 21
Thu Sep 30 15:41:37 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:37 2021 kern.info quectel-CM[11862]: Dail Failed 22
Thu Sep 30 15:41:42 2021 kern.info quectel-CM[11862]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 15:41:42 2021 kern.info quectel-CM[11862]: Dail Failed 23
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]:
2021-09-30 15:41:43 UTC
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: ### [UPSTREAM] ###
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # RF packets received by concentrator: 0
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # PUSH_DATA datagrams sent: 1 (135 bytes)
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # PUSH_DATA acknowledged: 100.00
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: ### [DOWNSTREAM] ###
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # PULL_DATA sent: 5 (100.00 acknowledged)
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # TX errors: 0
Thu Sep 30 15:41:43 2021 user.notice lora_pkt_fwd[2159]: # BEACON queued: 0
and this when connected via ssh and runnning the ps command:
BusyBox v1.23.2 (2021-08-26 13:50:51 UTC) built-in shell (ash)
LoRaWAN Gateway (WisGateOS 1.2.1_RAK 20210826)
root@RAK7268C:~# ps
PID USER VSZ STAT COMMAND
1 root 1508 S /sbin/procd
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
4 root 0 SW [kworker/0:0]
5 root 0 SW< [kworker/0:0H]
7 root 0 SW< [khelper]
83 root 0 SW< [writeback]
85 root 0 SW< [bioset]
88 root 0 SW< [kblockd]
90 root 0 SW [kworker/0:1]
91 root 0 SW [kswapd0]
92 root 0 SW [fsnotify_mark]
94 root 0 SW [spi32766]
253 root 0 SW< [deferwq]
298 root 0 SW [kworker/u2:2]
342 root 0 SW [mmcqd/0]
345 root 0 SW [kworker/u2:3]
402 root 0 SWN [jffs2_gcd_mtd7]
533 root 904 S /sbin/ubusd
551 root 768 S /sbin/askfirst /bin/login.sh
1086 root 0 SW< [ipv6_addrconf]
1361 root 1500 S {syslog.sh} /bin/sh /usr/bin/syslog.sh
1368 root 1208 S logread -f -F /tmp/log/20210930150344.log -p /var/ru
1398 root 1164 S /sbin/logd -S 64
1407 root 1820 S /sbin/rpcd
1455 root 1164 S /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p
1646 root 1248 S /usr/sbin/odhcpd
1683 root 1500 S /usr/sbin/crond -f -c /etc/crontabs -l 5
1791 root 0 SW [RtmpCmdQTask]
1795 root 0 SW [RtmpWscTask]
1796 root 0 SW [RtmpMlmeTask]
1857 root 5392 S /usr/sbin/uhttpd -f -h /www -r RAK7268C -x /cgi-bin
1875 root 776 S /usr/sbin/rteswplugd -r /etc/eswplug.action
1892 mosquitt 3776 S mosquitto -c /etc/mosquitto/mosquitto.conf
1952 root 4964 S /usr/bin/lua /usr/bin/data-broker.lua
2005 root 5492 S /usr/sbin/lorasrv -S -D /mnt/mmcblk0p1/lorasrv/mote_
2159 root 19508 S /usr/bin/lora_pkt_fwd -g /var/etc/global_conf.json -
2571 root 1624 S /sbin/netifd
2674 nobody 1000 S /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf -k -x /va
2738 root 804 S odhcp6c -s /lib/netifd/dhcpv6.script -P0 -t120 apcli
2767 root 1496 S udhcpc -p /var/run/udhcpc-apcli0.pid -s /lib/netifd/
2773 root 1496 S udhcpc -p /var/run/udhcpc-eth0.2.pid -s /lib/netifd/
2778 root 804 S odhcp6c -s /lib/netifd/dhcpv6.script -P0 -t120 eth0.
2869 root 784 S /sbin/ap_client ra0 apcli0 WIFI DETAILS REMOVED
3823 root 1500 S {mwan3track} /bin/sh /usr/sbin/mwan3track wan0 apcli
4353 root 1500 S /usr/sbin/ntpd -n -S /usr/sbin/ntpd-hotplug -p 0.ope
4364 root 1536 S {breathing_light} /bin/sh /sbin/breathing_light
4379 root 812 S /usr/bin/mpstat -f -t -u 5
22153 root 3108 S /usr/sbin/quectel -s 3iot.com
22195 root 0 SW [kworker/0:2]
23028 root 0 SW [kworker/u2:0]
23109 root 1496 S udhcpc -p /var/run/udhcpc-wwan0.pid -s /lib/netifd/d
23110 root 804 S odhcp6c -s /lib/netifd/dhcpv6.script -P0 -t120 wwan0
25293 root 1232 S /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p
25880 root 1488 S sleep 5
25906 root 1500 S -ash
25940 root 1560 S {mwan3} /bin/sh /usr/sbin/mwan3 status
25941 root 1492 S tee
25968 root 1488 S sleep 1
25991 root 1348 R {luci} /usr/bin/lua /www/cgi-bin/luci
25992 root 1496 R ps
root@RAK7268C:~#
So this is similar to what I had with the 7528. And the status light flashes blue but it still doesnât connect to LORIOT.
After running the command to turn off the other packet forwarder as recomended for the 7528 gateway ( /etc/init.d/packet_forwarder disable ; /etc/init.d/loriot-gw enable ; reboot now) I now get this and the status light flashes red so I think it is at this stage that something goes wrong:
Thu Sep 30 16:26:18 2021 user.err loriot_rak_7249_spi[11114]: ERROR: NOT EXPECTED CHIP VERSION (v0)
Thu Sep 30 16:26:18 2021 user.err loriot_rak_7249_spi[11114]: ERROR: FAIL TO CONNECT BOARD
Thu Sep 30 16:26:18 2021 user.err loriot_rak_7249_spi[11114]: lgw_start failed
Thu Sep 30 16:26:18 2021 user.err loriot_rak_7249_spi[11114]: You might be running an incompatible version of the binary
Thu Sep 30 16:26:18 2021 user.notice loriot_rak_7249_spi[11114]: Concentrator stopped
Thu Sep 30 16:26:18 2021 kern.info quectel-CM[1426]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 16:26:18 2021 kern.info quectel-CM[1426]: Dail Failed 31
Thu Sep 30 16:26:19 2021 user.notice syslog: Gateway loriot_rak_7249_spi version 2.8.1560-JKS-EU4PRO-10
Thu Sep 30 16:26:19 2021 user.notice syslog: Openssl version OpenSSL 1.0.2j 26 Sep 2016
Thu Sep 30 16:26:19 2021 user.notice loriot_rak_7249_spi[11331]: Using eth0 for GW EUI AC1F09FFFF053CF4
Thu Sep 30 16:26:19 2021 user.notice loriot_rak_7249_spi[11331]: Requesting system route
Thu Sep 30 16:26:19 2021 user.notice loriot_rak_7249_spi[11331]: Connecting config server eu4pro.loriot.io
Thu Sep 30 16:26:19 2021 user.notice loriot_rak_7249_spi[11331]: SSL: certificate database loaded
Thu Sep 30 16:26:22 2021 user.notice loriot_rak_7249_spi[11331]: HTTP response HTTP/1.1 200 OK
Thu Sep 30 16:26:22 2021 user.notice loriot_rak_7249_spi[11331]: Timestamp Thu, 30 Sep 2021 16:26:10 GMT
Thu Sep 30 16:26:22 2021 user.notice loriot_rak_7249_spi[11331]: Content-type application/json; charset=utf-8
Thu Sep 30 16:26:23 2021 kern.info quectel-CM[1426]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 16:26:23 2021 kern.info quectel-CM[1426]: Dail Failed 32
Thu Sep 30 16:26:24 2021 user.notice loriot_rak_7249_spi[11331]: HTTP response HTTP/1.1 204 No Content
Thu Sep 30 16:26:24 2021 user.notice loriot_rak_7249_spi[11331]: Starting LoRa Concentrator
Thu Sep 30 16:26:24 2021 user.err loriot_rak_7249_spi[11331]: ERROR: NOT EXPECTED CHIP VERSION (v0)
Thu Sep 30 16:26:24 2021 user.err loriot_rak_7249_spi[11331]: ERROR: FAIL TO CONNECT BOARD
Thu Sep 30 16:26:24 2021 user.err loriot_rak_7249_spi[11331]: lgw_start failed
Thu Sep 30 16:26:24 2021 user.err loriot_rak_7249_spi[11331]: You might be running an incompatible version of the binary
Thu Sep 30 16:26:24 2021 user.notice loriot_rak_7249_spi[11331]: Concentrator stopped
Thu Sep 30 16:26:25 2021 user.notice syslog: Gateway loriot_rak_7249_spi version 2.8.1560-JKS-EU4PRO-10
Thu Sep 30 16:26:25 2021 user.notice syslog: Openssl version OpenSSL 1.0.2j 26 Sep 2016
Thu Sep 30 16:26:25 2021 user.notice loriot_rak_7249_spi[11632]: Using eth0 for GW EUI AC1F09FFFF053CF4
Thu Sep 30 16:26:25 2021 user.notice loriot_rak_7249_spi[11632]: Requesting system route
Thu Sep 30 16:26:25 2021 user.notice loriot_rak_7249_spi[11632]: Connecting config server eu4pro.loriot.io
Thu Sep 30 16:26:25 2021 user.notice loriot_rak_7249_spi[11632]: SSL: certificate database loaded
Thu Sep 30 16:26:28 2021 user.notice loriot_rak_7249_spi[11632]: HTTP response HTTP/1.1 200 OK
Thu Sep 30 16:26:28 2021 user.notice loriot_rak_7249_spi[11632]: Timestamp Thu, 30 Sep 2021 16:26:28 GMT
Thu Sep 30 16:26:28 2021 user.notice loriot_rak_7249_spi[11632]: Content-type application/json; charset=utf-8
Thu Sep 30 16:26:28 2021 kern.info quectel-CM[1426]: requestRegistrationState2 MCC: 234, MNC: 30, PS: Detached, DataCap: UMTS
Thu Sep 30 16:26:28 2021 kern.info quectel-CM[1426]: Dail Failed 33
Thu Sep 30 16:26:29 2021 kern.info quectel-CM[1426]: QmiWwanThread exit
Thu Sep 30 16:26:29 2021 kern.info quectel-CM[1426]: main exit
Thu Sep 30 16:26:31 2021 kern.info quectel-CM[11922]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Thu Sep 30 16:26:31 2021 kern.info quectel-CM[11922]: /usr/sbin/quectel profile[1] = 3iot.com///0, pincode = (null)
Thu Sep 30 16:26:31 2021 user.notice root: echo 1 > /sys/class/gpio/gpio42/value
Thu Sep 30 16:26:31 2021 daemon.notice netifd: Network device âwwan0â link is down
Thu Sep 30 16:26:32 2021 user.notice loriot_rak_7249_spi[11632]: HTTP response HTTP/1.1 204 No Content
Thu Sep 30 16:26:32 2021 user.notice loriot_rak_7249_spi[11632]: Starting LoRa Concentrator
Thu Sep 30 16:26:32 2021 daemon.notice netifd: Interface âwwanâ has link connectivity loss
Thu Sep 30 16:26:32 2021 daemon.notice netifd: Interface âwwan6â has link connectivity loss
Thu Sep 30 16:26:32 2021 daemon.notice netifd: Interface âwwanâ is disabled
Thu Sep 30 16:26:32 2021 daemon.notice netifd: Interface âwwan6â is disabled
Thu Sep 30 16:26:32 2021 daemon.notice netifd: wwan (2787): Read error: Network is down, reopening socket
Thu Sep 30 16:26:32 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Thu Sep 30 16:26:32 2021 user.err loriot_rak_7249_spi[11632]: ERROR: NOT EXPECTED CHIP VERSION (v0)
Thu Sep 30 16:26:32 2021 user.err loriot_rak_7249_spi[11632]: ERROR: FAIL TO CONNECT BOARD
Thu Sep 30 16:26:32 2021 user.err loriot_rak_7249_spi[11632]: lgw_start failed
Thu Sep 30 16:26:32 2021 user.err loriot_rak_7249_spi[11632]: You might be running an incompatible version of the binary
Thu Sep 30 16:26:32 2021 user.notice loriot_rak_7249_spi[11632]: Concentrator stopped
Thu Sep 30 16:26:32 2021 user.notice root: echo 0 > /sys/class/gpio/gpio42/value
Thu Sep 30 16:26:33 2021 daemon.notice netifd: wwan (2787): udhcpc: bind: No such device
Thu Sep 30 16:26:33 2021 user.notice syslog: Gateway loriot_rak_7249_spi version 2.8.1560-JKS-EU4PRO-10
Thu Sep 30 16:26:33 2021 user.notice syslog: Openssl version OpenSSL 1.0.2j 26 Sep 2016
Thu Sep 30 16:26:33 2021 user.notice loriot_rak_7249_spi[12051]: Using eth0 for GW EUI AC1F09FFFF053CF4
Thu Sep 30 16:26:33 2021 user.notice loriot_rak_7249_spi[12051]: Requesting system route
Thu Sep 30 16:26:33 2021 user.notice loriot_rak_7249_spi[12051]: Connecting config server eu4pro.loriot.io
Thu Sep 30 16:26:33 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Thu Sep 30 16:26:34 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Thu Sep 30 16:26:34 2021 user.notice loriot_rak_7249_spi[12051]: SSL: certificate database loaded
Thu Sep 30 16:26:35 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Thu Sep 30 16:26:37 2021 user.notice loriot_rak_7249_spi[12051]: HTTP response HTTP/1.1 200 OK
Thu Sep 30 16:26:37 2021 user.notice loriot_rak_7249_spi[12051]: Timestamp Thu, 30 Sep 2021 16:26:26 GMT
Thu Sep 30 16:26:37 2021 user.notice loriot_rak_7249_spi[12051]: Content-type application/json; charset=utf-8
Thu Sep 30 16:26:40 2021 user.notice loriot_rak_7249_spi[12051]: HTTP response HTTP/1.1 204 No Content
Thu Sep 30 16:26:40 2021 user.notice loriot_rak_7249_spi[12051]: Starting LoRa Concentrator
Thu Sep 30 16:26:40 2021 user.err loriot_rak_7249_spi[12051]: ERROR: NOT EXPECTED CHIP VERSION (v0)
Thu Sep 30 16:26:40 2021 user.err loriot_rak_7249_spi[12051]: ERROR: FAIL TO CONNECT BOARD
Thu Sep 30 16:26:40 2021 user.err loriot_rak_7249_spi[12051]: lgw_start failed
Thu Sep 30 16:26:40 2021 user.err loriot_rak_7249_spi[12051]: You might be running an incompatible version of the binary
Thu Sep 30 16:26:40 2021 user.notice loriot_rak_7249_spi[12051]: Concentrator stopped
Thu Sep 30 16:26:41 2021 user.notice syslog: Gateway loriot_rak_7249_spi version 2.8.1560-JKS-EU4PRO-10
Thu Sep 30 16:26:41 2021 user.notice syslog: Openssl version OpenSSL 1.0.2j 26 Sep 2016
Thu Sep 30 16:26:41 2021 user.notice loriot_rak_7249_spi[12491]: Using eth0 for GW EUI AC1F09FFFF053CF4
Thu Sep 30 16:26:41 2021 user.notice loriot_rak_7249_spi[12491]: Requesting system route
Thu Sep 30 16:26:41 2021 user.notice loriot_rak_7249_spi[12491]: Connecting config server eu4pro.loriot.io
Thu Sep 30 16:26:42 2021 user.notice loriot_rak_7249_spi[12491]: SSL: certificate database loaded
Thu Sep 30 16:26:43 2021 user.notice loriot_rak_7249_spi[12491]: HTTP response HTTP/1.1 200 OK
Thu Sep 30 16:26:43 2021 user.notice loriot_rak_7249_spi[12491]: Timestamp Thu, 30 Sep 2021 16:26:31 GMT
Thu Sep 30 16:26:43 2021 user.notice loriot_rak_7249_spi[12491]: Content-type application/json; charset=utf-8
Thu Sep 30 16:26:43 2021 user.notice loriot_rak_7249_spi[12491]: HTTP response HTTP/1.1 204 No Content
Thu Sep 30 16:26:43 2021 user.notice loriot_rak_7249_spi[12491]: Starting LoRa Concentrator
Thu Sep 30 16:26:43 2021 user.err loriot_rak_7249_spi[12491]: ERROR: NOT EXPECTED CHIP VERSION (v0)
Thu Sep 30 16:26:43 2021 user.err loriot_rak_7249_spi[12491]: ERROR: FAIL TO CONNECT BOARD
Thu Sep 30 16:26:43 2021 user.err loriot_rak_7249_spi[12491]: lgw_start failed
Thu Sep 30 16:26:43 2021 user.err loriot_rak_7249_spi[12491]: You might be running an incompatible version of the binary
Thu Sep 30 16:26:44 2021 user.notice loriot_rak_7249_spi[12491]: Concentrator stopped
Thu Sep 30 16:26:45 2021 user.notice syslog: Gateway loriot_rak_7249_spi version 2.8.1560-JKS-EU4PRO-10
Thu Sep 30 16:26:45 2021 user.notice syslog: Openssl version OpenSSL 1.0.2j 26 Sep 2016
Thu Sep 30 16:26:45 2021 user.notice loriot_rak_7249_spi[12661]: Using eth0 for GW EUI AC1F09FFFF053CF4
Thu Sep 30 16:26:45 2021 user.notice loriot_rak_7249_spi[12661]: Requesting system route
Thu Sep 30 16:26:45 2021 user.notice loriot_rak_7249_spi[12661]: Connecting config server eu4pro.loriot.io
Thu Sep 30 16:26:45 2021 user.notice loriot_rak_7249_spi[12661]: SSL: certificate database loaded
Thu Sep 30 16:26:46 2021 user.notice loriot_rak_7249_spi[12661]: HTTP response HTTP/1.1 200 OK
Thu Sep 30 16:26:46 2021 user.notice loriot_rak_7249_spi[12661]: Timestamp Thu, 30 Sep 2021 16:26:46 GMT
Thu Sep 30 16:26:46 2021 user.notice loriot_rak_7249_spi[12661]: Content-type application/json; charset=utf-8
Thu Sep 30 16:26:46 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Thu Sep 30 16:26:47 2021 daemon.notice netifd: Interface âwwanâ is enabled
Thu Sep 30 16:26:47 2021 daemon.notice netifd: Interface âwwan6â is enabled
Thu Sep 30 16:26:47 2021 daemon.notice netifd: Network device âwwan0â link is up
Thu Sep 30 16:26:47 2021 daemon.notice netifd: Interface âwwanâ has link connectivity
Thu Sep 30 16:26:47 2021 daemon.notice netifd: Interface âwwanâ is setting up now
Thu Sep 30 16:26:47 2021 daemon.notice netifd: Interface âwwan6â has link connectivity
Thu Sep 30 16:26:47 2021 daemon.notice netifd: Interface âwwan6â is setting up now
So I guess a different command is required after installing the LORIOT software?
Thank you for your help / patience. Iâm an ecologist so this kind of stuff is out of my comfort zone and I would like to get to the bottom of this so I can provide a straightforward set up guide for other colleagues like I have done for the 7258 gateway.
