I got WisGate Connect Gateway and the RAK5148 to setup a LoRaWAN Gateway in 2.4GHz bands.
Is there an easy way to set the concentrator with rakpios-cli?
Thanks,
Thanks,
You can use the udp-packet-forwarder image (this one: GitHub - RAKWireless/udp-packet-forwarder: UDP Packet Forwarder for Docker · GitHub) which is available from rakpios-cli and select the RAK5148 as your module.
