Hi everyone, I’m setting up a weather station with the wisblock (4630), and the interface extension module. I have had all separate functions working in basic sketches. So I am now starting the process of integrating into the example OTAA sketch. Starting with an sht31 temp/humidity sensor. The problem is when I add a serial.print before compiling my payload, it causes the sketch to hang. It connects to the ttn, but no payload is sent, and it just stays in that condition…screenshot of the sketch below. If the lines are commented out, it works fine. Is there any way around this?
Hello @Andy
That is strange, I do not see a reason why the Serial.print should cause such a problem.
Two questions:
- what is
get_data;in your code? This line seems to make no sense - if you comment out the two lines of Serial.print, the data is sent and the Serial.print after sending (showing success or fail) are printing out the result?
Hi @beegee, sorry the get_data should have been commented out also…I tried a different tack and had this at the end of the sketch…which didn’t work either…
2. Yes, with the two lines commented out, it behaves as expected, sending a payload every LORAWAN_APP_INTERVAL
Here’s what’s happening when the lines are active…
It just hangs there, the ttn picks up the device initially, but no packet is sent.
I do not have an SHT31, but I will run a test later today with our RAK1901 (SHTC3).
Your code is based on the LoRaWAN_OTAA_ABP or some other example?
Yep, it is based on that code…Here is the full code i’ve been playing with…
There are only changes on lines 18,19,21,22,105-109,244-247.
* @note RAK4631 GPIO mapping to nRF52840 GPIO ports
RAK4631 <-> nRF52840
WB_IO1 <-> P0.17 (GPIO 17)
WB_IO2 <-> P1.02 (GPIO 34)
WB_IO3 <-> P0.21 (GPIO 21)
WB_IO4 <-> P0.04 (GPIO 4)
WB_IO5 <-> P0.09 (GPIO 9)
WB_IO6 <-> P0.10 (GPIO 10)
WB_SW1 <-> P0.01 (GPIO 1)
WB_A0 <-> P0.04/AIN2 (AnalogIn A2)
WB_A1 <-> P0.31/AIN7 (AnalogIn A7)
#include <Arduino.h>
#include <SPI.h>
#include "Adafruit_SHT31.h"
Adafruit_SHT31 sht31 = Adafruit_SHT31();
float t;
float h;
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
#define LORAWAN_DATERATE DR_0 /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_5 /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
DeviceClass_t g_CurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_AU915; /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_CONFIRMED_MSG; /* confirm/unconfirm packet definition*/
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
static lmh_callback_t g_lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler
//OTAA keys !!!! KEYS ARE MSB !!!!
uint8_t nodeDeviceEUI[8] = {0x00, 0xC8, 0xE4, 0x34, 0xC5, 0xA4, 0x94, 0x48};
uint8_t nodeAppEUI[8] = {0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x01, 0xA4, 0xBF};
uint8_t nodeAppKey[16] = {0x9D, 0x5C, 0x27, 0x04, 0x76, 0xA9, 0xDD, 0xDC, 0x01, 0x13, 0xDD, 0x3D, 0xDA, 0x4B, 0xDE, 0x2C};
// ABP keys
uint32_t nodeDevAddr = ???????;
uint8_t nodeNwsKey[16] = {};
uint8_t nodeAppsKey[16] = {};
// Private defination
#define LORAWAN_APP_INTERVAL 10000 /**< Defines for user timer, the application data transmission interval. 30s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
void setup()
pinMode(LED_BUILTIN, OUTPUT);
// Initialize LoRa chip.
lora_rak4630_init();
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
Serial.println("SHT31 test");
if (! sht31.begin(0x44)) { // Set to 0x45 for alternate i2c addr
Serial.println("Couldn't find SHT31");
while (1) delay(1);
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (g_CurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
return;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWan
err_code = lmh_init(&g_lora_callbacks, g_lora_param_init, doOTAA, g_CurrentClass, g_CurrentRegion);
if (err_code != 0)
return;
// Start Join procedure
lmh_join();
void loop()
// Put your application tasks here, like reading of sensors,
// Controlling actuators and/or other functions.
/**@brief LoRa function for handling HasJoined event.
if (ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
* @param[in] app_data Pointer to rx data
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, g_CurrentConfirm);
//Not joined, try again later
return;
// get_data;
t = sht31.readTemperature();
h = sht31.readHumidity();
Serial.print("Temp *C = "); Serial.println(t);
Serial.print("Hum. % = "); Serial.println(h);
uint32_t i = 0;
m_lora_app_data.buffer[i++] = t;
m_lora_app_data.buffer[i++] = 'e';
m_lora_app_data.buffer[i++] = 'l';
m_lora_app_data.buffer[i++] = 'o';
m_lora_app_data.buffer[i++] = '!';
m_lora_app_data.buffsize = i;
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
/**@brief Function for handling user timerout event.
send_lora_frame();
* @details Initializes the timer module. This creates and starts application timers.
return 0;
Getting the same problem with your code. Application hangs when the Serial.print is inside the send_lora_frame function to print a float value.
Possible explanation (only proven by code change):
send_lora_frame is called from a timer interrupt. Printing the float values from within the interrupt routine causes the crash.
Fix:
Define global variable bool send_triggered = false;
Call send_lora_frame() from the loop if send_triggered == true
void loop()
if (send_triggered)
send_lora_frame();
In tx_lora_periodic_handler() set send_triggered = true and DO NOT call send_lora_frame()
send_triggered = true;
// send_lora_frame();
Another tip, to make it easier to send the sensor values (you cannot send float numbers).
Define t and h as uint16_t
uint16_t t;
uint16_t h;
Read the values by multiplying the float by 100 into the int_16 variables and separate into fractional and integer.
t = sht31.readTemperature() * 100;
h = sht31.readHumidity() * 100;
uint8_t temp = t / 100;
uint8_t humid = h / 100;
uint16_t temp2 = t-(temp*100);
uint16_t humid2 = h-(humid*100);
Serial.print("Temp *C = "); Serial.print(temp);Serial.print(".");Serial.println(temp2);
Serial.print("Hum. % = "); Serial.print(humid);Serial.print(".");Serial.println(humid2);
Then you can just add the fractional and integer values into the LoRaWAN packet
uint32_t i = 0;
m_lora_app_data.buffer[i++] = temp;
m_lora_app_data.buffer[i++] = temp2;
m_lora_app_data.buffer[i++] = humid;
m_lora_app_data.buffer[i++] = humid2;
Here is the complete sketch with above changes:
@file LoRaWAN_OTAA_ABP.ino
@author rakwireless.com
@brief LoRaWan node example with OTAA/ABP registration
@version 0.1
@date 2020-08-21
@copyright Copyright (c) 2020
#include <SPI.h>
uint16_t t;
uint16_t h;
#ifndef LED_BUILTIN
#endif
#endif
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_AS923_3; /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_UNCONFIRMED_MSG; /* confirm/unconfirm packet definition*/
uint8_t nodeDeviceEUI[8] = {0xac, 0x1f, 0x09, 0xff, 0xfe, 0x01, 0x37, 0x29};
uint8_t nodeAppEUI[8] = {0xB8, 0x27, 0xEB, 0xFF, 0xFE, 0x39, 0x00, 0x00};
uint8_t nodeAppKey[16] = {0x2B, 0x84, 0xE0, 0xB0, 0x9B, 0x68, 0xE5, 0xCB, 0x42, 0x17, 0x6F, 0xE7, 0x53, 0xDC, 0xEE, 0x79};
// ABP keys
uint32_t nodeDevAddr = 0x260116F8;
uint8_t nodeNwsKey[16] = {0x7E, 0xAC, 0xE2, 0x55, 0xB8, 0xA5, 0xE2, 0x69, 0x91, 0x51, 0x96, 0x06, 0x47, 0x56, 0x9D, 0x23};
uint8_t nodeAppsKey[16] = {0xFB, 0xAC, 0xB6, 0x47, 0xF3, 0x58, 0x45, 0xC7, 0x50, 0x7D, 0xBF, 0x16, 0x8B, 0xA8, 0xC1, 0x7C};
#define LORAWAN_APP_INTERVAL 20000 /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
void setup()
while (!Serial)
delay(100);
else
break;
// while (1) delay(1);
if (doOTAA)
else
break;
break;
break;
case LORAMAC_REGION_CN779:
Serial.println("Region: CN779");
break;
break;
break;
break;
break;
break;
case LORAMAC_REGION_RU864:
Serial.println("Region: RU864");
break;
case LORAMAC_REGION_AS923_2:
Serial.println("Region: AS923-2");
break;
case LORAMAC_REGION_AS923_3:
Serial.println("Region: AS923-3");
break;
case LORAMAC_REGION_AS923_4:
Serial.println("Region: AS923-4");
break;
uint32_t err_code;
if (err_code != 0)
return;
if (doOTAA)
else
if (err_code != 0)
return;
lmh_join();
void loop()
if (send_triggered)
send_lora_frame();
delay(1000);
return;
uint16_t temp2 = t - (temp * 100);
uint16_t humid2 = h - (humid * 100);
Serial.print("Temp *C = "); Serial.print(temp); Serial.print("."); Serial.println(temp2);
Serial.print("Hum. % = "); Serial.print(humid); Serial.print("."); Serial.println(humid2);
uint32_t i = 0;
count++;
else
count_fail++;
return 0;
Excellent, thanks @beegee I would never have gotten that far. I really appreciate the assistance and suggestions. Will test soon.
As you have both discovered, you can’t do something as excruciatingly slow as a serial print inside an interrupt. Particularly if there is any chance of an interrupt being used to help get the data out the device, or DMA or similar.
Ideally the bare minimum is to set a flag & save any volatile data that you can’t pick up else where and then when the app gets back in to it’s main loop you can check the flag & print stuff.
Thank you! Very helpful. Your sage advice has assisted me with a timer issue I was having too
Trigger should also be declared as volatile.
volatile bool send_triggered = false;
