Hi everyone, I’m trying to get a sketch working which does 10 uplinks at a predetermined interval, then changes to a more standard interval (2 hrs). this is to make sure it’s all working well quite quickly.
For some reason my sketch doesn’t get to the count section of the sketch, it just keeps looping through at the original tx_interval…any assistance would be greatly appreciated!
#include <Arduino.h>
#include <SPI.h>
#include <LoRaWan-RAK4630.h>
/* Time the device is sleeping in milliseconds = 2 minutes * 60 seconds * 1000 milliseconds */
uint32_t tx_interval_start = 30000;
int tx_interval = 60000;
int change_tx_after = 10;
int current_sensor_payload;
TimerEvent_t appTimer;
static uint32_t count = 0;
//Battery Voltage************************************************************************
#define PIN_VBAT WB_A0
uint32_t vbat_pin = PIN_VBAT;
#define VBAT_MV_PER_LSB (0.73242188F) // 3.0V ADC range and 12 - bit ADC resolution = 3000mV / 4096
#define VBAT_DIVIDER_COMP (1.73) // Compensation factor for the VBAT divider, depend on the board
#define REAL_VBAT_MV_PER_LSB (VBAT_DIVIDER_COMP * VBAT_MV_PER_LSB)
/** DIO1 GPIO pin for RAK4631 */
#define PIN_LORA_DIO_1 47
// LoRaWan stuff
int8_t initLoRaWan(void);
bool sendLoRaFrame(void);
extern SemaphoreHandle_t loraEvent;
// Main loop stuff
void periodicWakeup(TimerHandle_t unused);
extern SemaphoreHandle_t taskEvent;
extern uint8_t rcvdLoRaData[];
extern uint8_t rcvdDataLen;
extern uint8_t eventType;
extern SoftwareTimer taskWakeupTimer;
/** Semaphore used by events to wake up loop task */
SemaphoreHandle_t taskEvent = NULL;
/** Timer to wakeup task frequently and send message */
/** Buffer for received LoRaWan data */
uint8_t rcvdLoRaData[256];
/** Length of received data */
uint8_t rcvdDataLen = 0;
uint8_t eventType = -1;
* @brief Timer event that wakes up the loop task frequently
* @param unused
// Switch off blue LED to save power during sleep
digitalWrite(LED_CONN, LOW);
eventType = 1;
// Give the semaphore, so the loop task will wake up
xSemaphoreGiveFromISR(taskEvent, pdFALSE);
/** Max size of the data to be transmitted. */
#define LORAWAN_APP_DATA_BUFF_SIZE 64
/** Number of trials for the join request. */
#define JOINREQ_NBTRIALS 8
/** Lora application data buffer. */
static uint8_t m_lora_app_data_buffer[LORAWAN_APP_DATA_BUFF_SIZE];
/** Lora application data structure. */
static lmh_app_data_t m_lora_app_data = {m_lora_app_data_buffer, 0, 0, 0, 0};
// LoRaWan event handlers
/** LoRaWan callback when join network finished */
/** LoRaWan callback when join failed */
/** LoRaWan callback when data arrived */
/** LoRaWan callback after class change request finished */
/** LoRaWan Function to send a package */
* Set structure members to
* LORAWAN_ADR_ON or LORAWAN_ADR_OFF to enable or disable adaptive data rate
* LORAWAN_DEFAULT_DATARATE OR DR_0 ... DR_5 for default data rate or specific data rate selection
* LORAWAN_PUBLIC_NETWORK or LORAWAN_PRIVATE_NETWORK to select the use of a public or private network
* JOINREQ_NBTRIALS or a specific number to set the number of trials to join the network
* LORAWAN_DEFAULT_TX_POWER or a specific number to set the TX power used
* LORAWAN_DUTYCYCLE_ON or LORAWAN_DUTYCYCLE_OFF to enable or disable duty cycles
* Please note that ETSI mandates duty cycled transmissions.
static lmh_param_t lora_param_init = {LORAWAN_ADR_ON, DR_0, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_DEFAULT_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
/** Structure containing LoRaWan callback functions, needed for lmh_init() */
static lmh_callback_t lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler};
// !!!! KEYS ARE MSB !!!!
/** Device EUI required for OTAA network join */
uint8_t nodeDeviceEUI[8] = {};
/** Application EUI required for network join */
uint8_t nodeAppEUI[8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
/** Application key required for network join */
uint8_t nodeAppKey[16] = {};
/** Device address required for ABP network join */
uint32_t nodeDevAddr = 0x26021FB6;
/** Network session key required for ABP network join */
uint8_t nodeNwsKey[16] = {0x32, 0x3D, 0x15, 0x5A, 0x00, 0x0D, 0xF3, 0x35, 0x30, 0x7A, 0x16, 0xDA, 0x0C, 0x9D, 0xF5, 0x3F};
/** Application session key required for ABP network join */
uint8_t nodeAppsKey[16] = {0x3F, 0x6A, 0x66, 0x45, 0x9D, 0x5E, 0xDC, 0xA6, 0x3C, 0xBC, 0x46, 0x19, 0xCD, 0x61, 0xA1, 0x1E};
/** Flag whether to use OTAA or ABP network join method */
bool doOTAA = true;
DeviceClass_t gCurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t gCurrentRegion = LORAMAC_REGION_AU915; /* Region:EU868*/
* @brief Initialize LoRa HW and LoRaWan MAC layer
* @return int8_t result
* 0 => OK
* -1 => SX126x HW init failure
* -2 => LoRaWan MAC initialization failure
* -3 => Subband selection failure
* -4 => LoRaWan handler task start failure
Serial.printf("<<>> lora_rak4630_init called at %dms\n", millis());
// Initialize LoRa chip.
if (lora_rak4630_init() != 0)
return -1;
Serial.printf("<<>> lora_rak4630_init finished at %dms\n", millis());
delay(100);
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
Serial.printf("<<>> lmh_init called at %dms\n", millis());
// Initialize LoRaWan
if (lmh_init(&lora_callbacks, lora_param_init, doOTAA, gCurrentClass, gCurrentRegion) != 0)
return -2;
Serial.printf("<<>> lmh_init finished at %dms\n", millis());
delay(100);
// For some regions we might need to define the sub band the gateway is listening to
// This must be called AFTER lmh_init()
if (!lmh_setSubBandChannels(2))
return -3;
// Start Join procedure
#ifndef MAX_SAVE
Serial.printf("<<>> lmh_join called at %dms\n", millis());
#endif
lmh_join();
Serial.printf("<<>> lmh_join finished at %dms\n", millis());
delay(100);
return 0;
* @brief LoRa function for handling HasJoined event.
Serial.printf("<<>> lorawan_has_joined_handler called at %dms\n", millis());
delay(100);
if (doOTAA)
uint32_t otaaDevAddr = lmh_getDevAddr();
#ifndef MAX_SAVE
Serial.printf("OTAA joined and got dev address %08X\n", otaaDevAddr);
#endif
else
#ifndef MAX_SAVE
Serial.println("ABP joined");
#endif
// Default is Class A, where the SX1262 transceiver is in sleep mode unless a package is sent
// If switched to Class C the power consumption is higher because the SX1262 chip remains in RX mode
// lmh_class_request(CLASS_C);
// Now we are connected, start the timer that will wakeup the loop frequently
taskWakeupTimer.begin(tx_interval_start, periodicWakeup);
taskWakeupTimer.start();
eventType = 1;
// Notify task about the event
if (taskEvent != NULL)
Serial.printf("<<>> Waking up task at %dms\n", millis());
xSemaphoreGive(taskEvent);
Serial.println("OVER_THE_AIR_ACTIVATION failed!");
* @brief Function for handling LoRaWan received data from Gateway
* @param app_data Pointer to rx data
#ifndef MAX_SAVE
Serial.printf("LoRa Packet received on port %d, size:%d, rssi:%d, snr:%d\n",
app_data->port, app_data->buffsize, app_data->rssi, app_data->snr);
#endif
switch (app_data->port)
case 3:
// Port 3 switches the class
if (app_data->buffsize == 1)
switch (app_data->buffer[0])
case 0:
lmh_class_request(CLASS_A);
#ifndef MAX_SAVE
Serial.println("Request to switch to class A");
#endif
break;
case 1:
lmh_class_request(CLASS_B);
#ifndef MAX_SAVE
Serial.println("Request to switch to class B");
#endif
break;
case 2:
#ifndef MAX_SAVE
Serial.println("Request to switch to class C");
#endif
break;
default:
break;
break;
case LORAWAN_APP_PORT:
// Copy the data into loop data buffer
memcpy(rcvdLoRaData, app_data->buffer, app_data->buffsize);
rcvdDataLen = app_data->buffsize;
eventType = 0;
// Assuming the new time is encoded as 3 bytes. e.g. 30=> 0x00, 0x00, 0x1F
// Downlink must be sent on Port2
// Downlink is in seconds
uint32_t new_time = app_data->buffer[0] << 16;
new_time |= app_data->buffer[1] << 8;
new_time |= app_data->buffer[2];
tx_interval_start = new_time * 1000;
Serial.print("New Time Set ");Serial.println(new_time);
Serial.print("Sleep Time ");Serial.println(tx_interval_start);
taskWakeupTimer.stop();
taskWakeupTimer.setPeriod(tx_interval_start);
#ifndef MAX_SAVE
Serial.println("Waking up loop task");
#endif
* @brief Callback for class switch confirmation
* @param Class The new class
#ifndef MAX_SAVE
#endif
m_lora_app_data.buffsize = 0;
m_lora_app_data.port = LORAWAN_APP_PORT;
lmh_send(&m_lora_app_data, LMH_UNCONFIRMED_MSG);
* @brief Send a LoRaWan package
* @return result of send request
//Not joined, try again later
#ifndef MAX_SAVE
Serial.println("Did not join network, skip sending frame");
#endif
return false;
//Battery Voltage**********************************************************************************
// Get a raw ADC reading
analogReference(AR_INTERNAL_3_0);
delay(50);
int vbat_mv = readVBAT();
int vbat_VOLT = (vbat_mv / 10) - 300;
analogReference(AR_INTERNAL); //This takes it back to default (3.6V), so wind direction has full resistance
// Convert from raw mv to percentage (based on LIPO chemistry)
uint8_t vbat_per = mvToPercent(vbat_mv);
/* WisBLOCK 5801 Power On*/
pinMode(WB_IO1, OUTPUT);
digitalWrite(WB_IO1, HIGH);
delay(1000);
int i;
int sensor_pin = A1; // select the input pin for the potentiometer
int mcu_ain_value = 0;
int pressure; //KPa as unit
int average_value;
float voltage_ain;
float current_sensor; // variable to store the value coming from the sensor
for (i = 0; i < 10; i++)
mcu_ain_value += analogRead(sensor_pin);
/* WisBLOCK 5801 Power Off*/
digitalWrite(WB_IO1, LOW);
average_value = mcu_ain_value / i;
voltage_ain = average_value * 3.6 /1024; //raef 3.6v / 10bit ADC
current_sensor = voltage_ain / 149.9 * 1000; //WisBlock RAK5801 I=U/149.9\*1000 (mA)
current_sensor_payload = current_sensor * 1000;
// Serial.printf("-------average_value------- = %d\n", average_value);
// Serial.printf("-------current_sensor------ = %f\n", current_sensor);
// Serial.printf("--current_sensor_payload--- = %d\n", current_sensor_payload);
// Serial.printf("----------Voltage (mV)----- = %d\n", vbat_mv);
uint32_t buffSize = 0;
m_lora_app_data_buffer[buffSize++] = highByte(current_sensor_payload);
m_lora_app_data_buffer[buffSize++] = lowByte(current_sensor_payload);
m_lora_app_data_buffer[buffSize++] = vbat_mv / 20;
// m_lora_app_data_buffer[buffSize++] = 'l';
// m_lora_app_data_buffer[buffSize++] = 'o';
m_lora_app_data.buffsize = buffSize;
lmh_error_status error = lmh_send(&m_lora_app_data, LMH_UNCONFIRMED_MSG);
return (error == 0);
if (error == LMH_SUCCESS)
count++;
if (count > change_tx_after) {
tx_interval_start = tx_interval;
Serial.printf("Frame count over set limit - interval now set to %d\n", tx_interval);
else
count_fail++;
void setup(void)
pinMode(17, OUTPUT);
digitalWrite(17, HIGH);
// Set the analog reference to 3.0V (default = 3.6V)
// analogReference(AR_INTERNAL_3_0);
// Let the ADC settle
delay(1);
// Get a single ADC sample and throw it away
float readVBAT();
// Create the LoRaWan event semaphore
taskEvent = xSemaphoreCreateBinary();
// Initialize semaphore
// Initialize the built in LED
pinMode(LED_BUILTIN, OUTPUT);
// Initialize the connection status LED
pinMode(LED_CONN, OUTPUT);
#ifndef MAX_SAVE
time_t timeout = millis();
while (!Serial)
delay(100);
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
else
break;
#endif
#ifndef MAX_SAVE
#endif
// Initialize LoRaWan and start join request
int8_t loraInitResult = initLoRaWan();
#ifndef MAX_SAVE
if (loraInitResult != 0)
switch (loraInitResult)
case -1:
Serial.println("SX126x init failed");
break;
case -2:
Serial.println("LoRaWan init failed");
break;
case -3:
Serial.println("Subband init error");
break;
case -4:
Serial.println("LoRa Task init error");
break;
default:
Serial.println("LoRa init unknown error");
break;
// Without working LoRa we just stop here
while (1)
Serial.println("Nothing I can do, just loving you");
delay(5000);
Serial.println("LoRaWan init success");
#endif
// Take the semaphore so the loop will go to sleep until an event happens
xSemaphoreTake(taskEvent, 10);
* @brief Arduino loop task. Called in a loop from the FreeRTOS task handler
void loop(void)
// Switch off blue LED to show we go to sleep
// digitalWrite(LED_BUILTIN, LOW);
// Sleep until we are woken up by an event
if (xSemaphoreTake(taskEvent, portMAX_DELAY) == pdTRUE)
// Switch on blue LED to show we are awake
delay(500); // Only so we can see the blue LED
// Check the wake up reason
switch (eventType)
case 0: // Wakeup reason is package downlink arrived
#ifndef MAX_SAVE
Serial.println("Received package over LoRaWan");
#endif
if (rcvdLoRaData[0] > 0x1F)
#ifndef MAX_SAVE
Serial.printf("%s\n", (char *)rcvdLoRaData);
#endif
else
#ifndef MAX_SAVE
for (int idx = 0; idx < rcvdDataLen; idx++)
Serial.printf("%X ", rcvdLoRaData[idx]);
Serial.println("");
#endif
break;
case 1: // Wakeup reason is timer
#ifndef MAX_SAVE
Serial.println("Timer wakeup");
#endif
/// \todo read sensor or whatever you need to do frequently
// Send the data package
if (sendLoRaFrame())
#ifndef MAX_SAVE
Serial.println("LoRaWan package sent successfully");
#endif
else
#ifndef MAX_SAVE
Serial.println("LoRaWan package send failed");
/// \todo maybe you need to retry here?
#endif
break;
default:
#ifndef MAX_SAVE
Serial.println("This should never happen ;-)");
#endif
break;
// Go back to sleep
Serial.println("Going back to sleep ;-)");
float readVBAT(void)
float raw;
// Get the raw 12-bit, 0..3000mV ADC value
analogReadResolution(12);
raw = analogRead(vbat_pin);
delay(50);
analogReadResolution(10);
return raw * REAL_VBAT_MV_PER_LSB;
uint8_t mvToPercent(float mvolts)
if (mvolts < 3300)
return 0;
if (mvolts < 3600)
mvolts -= 3300;
return mvolts / 30;
mvolts -= 3600;
return 10 + (mvolts * 0.15F); // thats mvolts /6.66666666
@brief get LoRaWan Battery value
@param mvolts
Raw Battery Voltage
uint8_t mvToLoRaWanBattVal(float mvolts)
if (mvolts < 3300)
return 0;
if (mvolts < 3600)
mvolts -= 3300;
return mvolts / 30 * 2.55;
mvolts -= 3600;
return (10 + (mvolts * 0.15F)) * 2.55;
