I am testing the RAK4600 module and have some questions about the power consumption.
When the board is first powered on it consumes about 290uA
When I join the LoRaWAN network using OTAA it then uses 2.89mA after joining
I then put the device to sleep with the command at+set_config=device:sleep:1 and the current only drops to 2.48mA. If I don’t join the network first then the current actually goes up when the device is put to sleep!
The specification says a sleep current of 2.0uA. How do I achieve this?
The firmware version is 3.0.0.8 and I am using an Otii ARC to measure the current consumption
I am sending the commands via the Otii UART interface to UART2 on the board.
As you can see from the pictures the module responds to the sleep command but the current consumption goes up if you haven’t joined or only very slightly down if you have. It is nowhere near the advertised value.
It is recommended that you use bluetooth to send, or sleep after removing the UART serial port connection.
By the way, you can modulate the voltage to 2.0V.
