I have an application where I have a RAK4630 receiving UART data from an external device, and sleep.all() behaves strangely.
What should happen:
The module should wake up from an interrupt, wait some delay to allow bytes to fill the buffer, parse those bytes, and then go back to sleep again.
What actually happens:
Before T=30 seconds the module does not seem to handle interrupts as it should, after T=30 seconds, interrupts seem to trigger when they are supposed to, but Serial data I should be parsing doesn’t make it through. The sleep timer is also wrong after T=30s as well, for long delays it can be almost double what is intended.
Here’s my code:
unsigned long ts = 0;
void setup() {
Serial0.begin(9600, RAK_CUSTOM_MODE);
Serial.begin(115200, RAK_CUSTOM_MODE);
api.system.sleep.setup(RUI_WAKEUP_FALLING_EDGE, P0_15);
void loop() {
if (Serial0.available() == 0) {
Serial.print("sleeping...");
ts = millis();
api.system.sleep.all(200);
Serial.print("awake after "); Serial.print(millis() - ts); Serial.print("ms! millis():");Serial.println(millis());
delay(5); //wait for data to hit the buffer
else {
delay(10); //wait for rest of data
for (int i = 0; i < Serial0.available(); i++) {
digitalWrite(P1_04, HIGH);
Serial.print("Serial0: "); Serial.println(Serial0.read(), HEX);
digitalWrite(P1_04, LOW);
Serial log:
awake after 200ms! millis():7355
sleeping…awake after 200ms! millis():7560
sleeping…awake after 200ms! millis():7765
sleeping…awake after 200ms! millis():7970
sleeping…awake after 200ms! millis():8175
sleeping…awake after 200ms! millis():8380
sleeping…awake after 200ms! millis():8585
sleeping…awake after 200ms! millis():8790
sleeping…awake after 200ms! millis():8995
sleeping…awake after 200ms! millis():9200
sleeping…awake after 200ms! millis():9405
Serial0: 1
Serial0: 6
Serial0: 90
sleeping…awake after 200ms! millis():9630
sleeping…awake after 200ms! millis():9835
Serial0: 9
Serial0: 6
Serial0: 10
sleeping…awake after 200ms! millis():10060
sleeping…awake after 200ms! millis():10265
sleeping…awake after 200ms! millis():10470
sleeping…awake after 200ms! millis():10675
sleeping…awake after 200ms! millis():10880
sleeping…awake after 200ms! millis():11085
sleeping…awake after 200ms! millis():11290
Serial0: 0
Serial0: 6
Serial0: A0
sleeping…awake after 200ms! millis():11515
sleeping…awake after 200ms! millis():11720
sleeping…awake after 200ms! millis():11925
sleeping…awake after 200ms! millis():12130
sleeping…awake after 200ms! millis():12335
sleeping…awake after 200ms! millis():12540
sleeping…awake after 200ms! millis():12745
sleeping…awake after 200ms! millis():12950
Serial0: 1
Serial0: 6
Serial0: 90
sleeping…awake after 200ms! millis():13175
sleeping…awake after 200ms! millis():13380
Serial0: 9
Serial0: 6
Serial0: 10
sleeping…awake after 200ms! millis():13605
sleeping…awake after 200ms! millis():13810
Serial0: 1
Serial0: 6
Serial0: 90
sleeping…awake after 200ms! millis():14035
sleeping…awake after 200ms! millis():14240
sleeping…awake after 200ms! millis():14445
sleeping…awake after 200ms! millis():14650
sleeping…awake after 200ms! millis():14855
sleeping…awake after 200ms! millis():15060
sleeping…awake after 200ms! millis():15265
sleeping…awake after 200ms! millis():15470
Serial0: 0
Serial0: 6
Serial0: A0
sleeping…awake after 200ms! millis():15695
sleeping…awake after 200ms! millis():15900
sleeping…awake after 200ms! millis():16105
sleeping…awake after 200ms! millis():16310
sleeping…awake after 200ms! millis():16515
sleeping…awake after 200ms! millis():16720
sleeping…awake after 200ms! millis():16926
sleeping…awake after 200ms! millis():17131
Serial0: 1
Serial0: 6
Serial0: 90
sleeping…awake after 200ms! millis():17356
sleeping…awake after 200ms! millis():17561
Serial0: 9
Serial0: 6
Serial0: 10
sleeping…awake after 200ms! millis():17786
sleeping…awake after 200ms! millis():17991
Serial0: 1
Serial0: 6
Serial0: 90
sleeping…awake after 200ms! millis():18216
sleeping…awake after 200ms! millis():18421
sleeping…awake after 200ms! millis():18626
sleeping…awake after 200ms! millis():18831
sleeping…awake after 200ms! millis():19037
sleeping…awake after 200ms! millis():19242
sleeping…awake after 200ms! millis():19447
sleeping…awake after 200ms! millis():19652
sleeping…awake after 200ms! millis():19857
sleeping…awake after 200ms! millis():20062
Serial0: 0
Serial0: 6
Serial0: A0
sleeping…awake after 200ms! millis():20289
sleeping…awake after 200ms! millis():20494
sleeping…awake after 200ms! millis():20699
sleeping…awake after 200ms! millis():20904
sleeping…awake after 200ms! millis():21109
sleeping…awake after 200ms! millis():21314
sleeping…awake after 200ms! millis():21519
sleeping…awake after 200ms! millis():21725
sleeping…awake after 200ms! millis():21930
sleeping…awake after 200ms! millis():22135
sleeping…awake after 200ms! millis():22340
sleeping…awake after 200ms! millis():22545
sleeping…awake after 200ms! millis():22750
sleeping…awake after 200ms! millis():22955
sleeping…awake after 200ms! millis():23160
sleeping…awake after 200ms! millis():23365
sleeping…awake after 200ms! millis():23570
sleeping…awake after 200ms! millis():23775
sleeping…awake after 200ms! millis():23980
sleeping…awake after 200ms! millis():24185
sleeping…awake after 200ms! millis():24390
sleeping…awake after 200ms! millis():24595
sleeping…awake after 200ms! millis():24800
sleeping…awake after 200ms! millis():25005
sleeping…awake after 200ms! millis():25210
sleeping…awake after 200ms! millis():25415
sleeping…awake after 200ms! millis():25620
sleeping…awake after 200ms! millis():25825
sleeping…awake after 200ms! millis():26030
sleeping…awake after 200ms! millis():26235
sleeping…awake after 200ms! millis():26440
sleeping…awake after 200ms! millis():26645
sleeping…awake after 200ms! millis():26850
sleeping…awake after 200ms! millis():27055
sleeping…awake after 200ms! millis():27260
sleeping…awake after 200ms! millis():27465
sleeping…awake after 200ms! millis():27670
sleeping…awake after 200ms! millis():27875
sleeping…awake after 200ms! millis():28080
sleeping…awake after 200ms! millis():28285
sleeping…awake after 200ms! millis():28490
sleeping…awake after 200ms! millis():28695
sleeping…awake after 200ms! millis():28900
sleeping…awake after 200ms! millis():29105
sleeping…awake after 200ms! millis():29310
sleeping…awake after 200ms! millis():29515
sleeping…awake after 200ms! millis():29720
sleeping…awake after 200ms! millis():29925
sleeping…awake after 200ms! millis():30130
sleeping…awake after 200ms! millis():30335
sleeping…awake after 232ms! millis():30572
sleeping…awake after 218ms! millis():30795
sleeping…awake after 218ms! millis():31018
sleeping…awake after 218ms! millis():31241
sleeping…awake after 218ms! millis():31464
sleeping…awake after 217ms! millis():31686
sleeping…awake after 9ms! millis():31700
Serial0: 9
Serial0: 6
Serial0: 10
sleeping…awake after 117ms! millis():31843
Serial0: 1
Serial0: 6
Serial0: 90
sleeping…awake after 117ms! millis():31985
Serial0: 0
Serial0: 6
Serial0: A0
sleeping…awake after 218ms! millis():32228
sleeping…awake after 218ms! millis():32451
sleeping…awake after 218ms! millis():32674
sleeping…awake after 218ms! millis():32897
sleeping…awake after 218ms! millis():33120
sleeping…awake after 109ms! millis():33234
sleeping…awake after 217ms! millis():33456
sleeping…awake after 9ms! millis():33470
Serial0: 9
Serial0: 6
Serial0: 10
sleeping…awake after 117ms! millis():33613
Serial0: 1
Serial0: 6
Serial0: 90
sleeping…awake after 118ms! millis():33757
sleeping…awake after 217ms! millis():33979
sleeping…awake after 218ms! millis():34202
sleeping…awake after 218ms! millis():34425
sleeping…awake after 218ms! millis():34648
sleeping…awake after 218ms! millis():34871
sleeping…awake after 218ms! millis():35095
sleeping…awake after 218ms! millis():35319
sleeping…awake after 218ms! millis():35542
sleeping…awake after 218ms! millis():35766
sleeping…awake after 218ms! millis():35989
sleeping…awake after 218ms! millis():36212
Could this be related to BLE advertising somehow? Seems about the time that BLE stops advertising after startup. @beegee any chance you know of a workaround? This is from staging, by the way.
