RAK WisBlock.
Where can I get a longer threaded SMA to ipex lead? because all the ones I keep buying do NOT have a long enough thread to go through the Unify box and connect to the external antenna?
As shown in this video: https://youtu.be/6u5v6RS4P-A?si=pnnGVAViMxK1Hfu4
Welcome to the forum @TheDrayman
Did you see our iPEX to RP-SMA Connector?
Cable length 220mm, that should be more than enough for even the largest Unify enclosure.
Thanks for replying. It was not the cable length I meant it was the SMA connector. After slowing down the video and going frame-by-frame I notice that the hole the connector was in had been recessed, so I kind of fixed that in my build.
