I want to make a gas monitoring sensor with an MQ2 sensor. This type of sensor consumes a lot of energy since the sensor must heat up to correctly sense LPG gas in the environment.
Can I connect a 110 AC to 5V DC 1 amp transformer to the solar panel input?
example: https://www.amazon.com/-/es/voltios-adaptador-cargador-fuente-alimentación/dp/B0772DM9XW
The idea is that it has its battery in case there is no power, the lithium battery should remain operational for a minimum of 8 hours until the power is restored.
reading datashet does not indicate the mA it supports.
I look forward to your comments or advice.
