Hello guys,
I came about WisBlock while looking for Arduino parts for my project… brand new to WisBlock so need you help on my first project.
I work for a hazmat transportation company; we want to build a solar powered solution to be installed on our gas tank trailers that sends a 4-20mA pressure transducer readings along with GPS data.
Our device should wake up every X minute:
- Get the reading from the 4-20 pressure transducer
- Get GPS location
- Send information via LTE
- Sleep
After extensive reading I came up with this hardware list:
- Base: Dual IO Base Board with Power Slot | RAK19011
- Core: Nordic nRF52840 BLE Core Module for LoRaWAN with LoRa SX1262 | RAK4631
- IO1: 4-20mA Module STMicroelectronics LM2902 | RAK5801
- Power: USB LiPo Solar Power Slot Module | RAK19012
- Solar and enclosure: Unify Enclosure IP67 150x100x45mm with solar panel
- Battery: 3.7v 3200 mAh Link
- IO2: Not sure which one to get:
- NB-IoT LTE CAT M1 Quectel BG77 | Cellular IoT Module | RAK5860
or - GSM Quectel MC20CE | RAK13101
I want to power the 4-20 transducer directly off the RAK5801 module, the pressure transducer is an 8-12V input 4-20 mA: Link
Questions:
- Would WizBlock be a correct option overall? High vibration from the road is to be expected.
- Which cellular module is best for my use? RAK5860 or RAK13101
- I will not be using any other connectivity other than cellular, should I get other core module? (maybe having LoRa and BLE increases the power consumption?)
- What would the power consumption taking into consideration the pressure transducer looks like? Do you think this is feasible?
