Greetings all,
I have a RAK3172 on an RAK3272S breakout board. I’m able to connect successfully via serial using a SiLabs CP2102N connected to my Mac. The device responds normally to AT commands via the Arduino console and WisToolBox seems works fine.
When I attempt to implement the Standalone RUI3 Example it fails at Step 9 with the following error:
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.SLAB_USBtoUART, /dev/cu.usbserial-14210, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.SLAB_USBtoUART, /dev/tty.usbserial-14210, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.SLAB_USBtoUART, /dev/cu.usbserial-14210, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.SLAB_USBtoUART, /dev/tty.usbserial-14210, } => {}
Uploading using selected port: /dev/cu.SLAB_USBtoUART
python3 /Users/keck/Library/Arduino15/packages/rak_rui/tools/uploader_ymodem/1.0.0/uploader_ymodem.py -f /var/folders/xt/b2nqyds519x10nn0hytgbw5r0000gn/T/arduino_build_160172/Arduino_Digital-mod.ino.bin -p /dev/cu.SLAB_USBtoUART
File "/Users/keck/Library/Arduino15/packages/rak_rui/tools/uploader_ymodem/1.0.0/uploader_ymodem.py", line 6, in <module>
import serial
ModuleNotFoundError: No module named 'serial'
Some other searching suggested it might be a missing pyserial library, however it appears I already have this installed:
%pip install pyserial
Requirement already satisfied: pyserial in ./.pyenv/versions/3.9.0/lib/python3.9/site-packages (3.5)
Any advice on how to diagnose further?
Thanks!
-AD
