we have a bunch of RAK2287-USB modules. If I try to get their chip ID for the first time, I get an MCU version mismatch:
cd ~/lora/sx1302_hal-master/tools ; sudo ../util_chip_id/chip_id -u -d /dev/ttyACM0
Opening USB communication interface
INFO: Configuring TTY
INFO: Flushing TTY
INFO: Setting TTY in blocking mode
INFO: Connect to MCU
WARNING: MCU version mismatch (expected:01.00.00, got:V00.02.06)
INFO: Concentrator MCU version is V00.02.06
INFO: MCU status: sys_time:42671 temperature:-0.0oC
ERROR: received wrong ACK type (0xFF)
ERROR: failed to read REQ_MULTIPLE_SPI ack
ERROR: failed to start the gateway
I then use dfu-util to flash a new firmware:
cd ~/lora/sx1302_hal-master/util_boot ; ./boot -d /dev/ttyACM0
sudo dfu-util -a 0 -s 0x08000000:leave -t 0 -D ../mcu_bin/rlz_010000_CoreCell_USB.bin
When this works, I can get the EUI afterwards. But on some modules, it fails:
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 0483:df11
Run-time device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 2048
DfuSe interface name: "Internal Flash "
Downloading to address = 0x08000000, size = 35724
Download [= ] 5% 2048 bytesdfu-util: Error during special command "ERASE_PAGE" get_status
Afterwards, I’m unsure if and how I can reset the module to a state where I can try again. Running the boot utility disables serial access, and there doesn’t seem to be an additional switch to undo that. What do I do to salvage these chips?
