Restarts after 2-3 minutes if you send it to sleep. what can this be related to?! Screenshot 2020-10-26 00.13.36|690x411
Hello @davinci102,
I think I’m having the same problem. Did you find a solution?
These are my results so far (in a custom board):
As soon as the RAK4600 has initialized I join ABP and then send SLEEP.
UPDATE: I tested the problem using the Eval Kit and the problem was also detected. The issue appears once the RAK4600 is set to sleep mode. If I don’t set sleep, then the RAK4600 does not restart by itself.
Here’s a video with the situation.
I am using the firmware version 3.4.0.14 on the Evaluation Board, using the USB connection with the RAK Serial Port Tool.
Perhaps someone could share with me a previous firmware version and its documentation? I would like to try it.
Hi @nicolasech , this is not at the official FW yet from our software team but I recompiled the RAK4600 FW with the update RUI. You can try this FW. You should see 3.4.0.16. I tested it now with sleep command and I got no restart on the module.
