Hi, I need some newbie advice to get this module going, so beare with me.
Running:
RAK3172-E (RAK3372)
AT+VER=RUI_4.2.0_RAK3172-E
Arduino IDE 2.3.4
Working:
The RUI3-RAK1901-RAK1902-Example works fine, joining and data Ok.
Problems:
With the RUI3-RAK12500-RAK1904-GNSS without the GNSS module.
Compiling works after reducing numbers of supported regions with original Adafruit library for LIS3dh.
Upload seems fine, but after this the at commands are not responsive and I cannot upload without flashing new firmware!?
I’m not sure how to use the custom libraries, is this a required?
Regarding the RUI3-RAK12500-RAK1904-GNSS example, the above change helped there too
RAKwireless RUI3 Location Tracker
[SETUP] Create timer for interrupt handler
[SETUP] Confirmed mode disabled
[SETUP] Retry = 0
[SETUP] DR = 3
[ACC] ACC sensor initialization begin...
[ACC] Interrupt pin setup complete
[ACC] I2C communication initialized
[ACC] Accelerometer data rate and range set
Current Work Mode: LoRaWAN.
[GNSS] Could not initialize RAK12500 on Wire
[GNSS] Got location
[UPLINK] Packet enqueued, size 23
[TX-CB] TX status 0
[RX-CB] RX, port 0, DR 3, RSSI -34, SNR 10
+EVT:TX_DONE
[ACC] GNSS not active, time since last trigger 26.043 s
[UPLINK] ACC triggered IRQ
[GNSS] Got location
[TX-CB] TX status 0
[RX-CB] RX, port 0, DR 5, RSSI -33, SNR 10
+EVT:TX_DONE
